Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > BCX/CX2/CX3
BCX/CX2/CX3 Blade (eFlite) CX, CX2 and CX3 Helicopters Information and Help
Old 01-02-2007, 12:48 PM   #1
racerman27410
Default Tail wag when using DX7 w my CX2
Hi,
First post here but have been lurking and reading alot :-)
Anyway i bought a DX7 to use with my MX400 and thought it might be fun to bind it to the stock Rx in my CX2.... no problems binding and reversing a couple of the servo switches but when i tried to fly the CX2 it had real bad tail wag.
i played with the 4in1 gain but couldnt adjust it out.
went back to the stock Tx and the tail is solid again.
was i missing somthing in the setup of the DX7 Tx or was it just overpowering the CX2 receiver?
thanks in advance,
Frank
racerman27410 is offline        Reply With Quote
Old 01-02-2007, 03:18 PM   #2
jut8
Interesting! I was just going to put up a post to see if I could use my DX7 with the CX2. I got my DX7 for my T-Rex, and i just got a CX2 ordered up. Could there possibly be some mixing in the radio that we might need to change? If anyone has any advice, please let us know, i really want to try to bind my DX7 to the CX2 i have coming also. Thanks!
jut8 is offline        Reply With Quote
Old 01-02-2007, 08:08 PM   #3
jut8
Anyone?
Old 01-03-2007, 05:25 PM   #4
carlo_the_wonder_frog
Yes the DX7 works just fine with the CX2. Program for single servo swash, its very easy to setup if you have experience with other Helis. Make sure you bind it correctly and set the failsafe. As far as tail wag, make sure you don't have any revo mixing turned on, just set the correct gain on the 4-in-1.
I have a few Heli's.
carlo_the_wonder_frog is offline        Reply With Quote
Old 01-04-2007, 03:52 PM   #5
Rastaman
Frank,
Thanks for your help with the setup. Initially I had the same tail wag that you experienced, however I was able to almost eliminate it by reducing the 'Gain Trimmer Pot' on the 4in1. Also it makes a difference if you fly with the 'front body' on or off the bird, I had a lot more tail wag when the 'front body' was off. I guess it affects the CG. Hope this helps.
Rastaman is offline        Reply With Quote
Old 01-05-2007, 04:33 PM   #6
jut8
Ok, another DX7 question, i got the bond, and my servos move great, but i am not getting any response from my throttle, and my red light wont go green. I tried reversing the throttle servo and that didnt help, Any other suggestions??
Old 01-06-2007, 07:49 AM   #7
jut8
Ok, i got it figured out, I had to drop my throttle trim way down, then i adjusted the gain, now she flys like a dream! :mrgreen:
