| MA Gas Miniature Aircraft Gas Helicopter Support Forum |
Whats the rear hole in the bottom of the rudder bellcrank for, my machine would set up better using this hole but the material is a bit thinner.
That is just the stock "bossing" on the molded part. The bell-crank is not new to the Spectra-G and has been used for years in various models. The "offset" hole is for collective use on the older X-Cell models.
Just make sure that the holes (upper and lower) on the molded boss are directly over each other at neutral and the servo wheel has the ball at the bottom. This will have you to use the holes in the thick part of the bossed bell-crank. Then make the rod the length needed to set these in place with the radio on. Later, BIGRCR
BIGRCR- John Garst Toxic Racing Motors IRCHA #1716 |
