Old 10-23-2010, 01:54 AM   #1
Mr._Torque
Default Swash mix DX6i
Did anyone set all the Swash mix to 125% on the DX6i radio? Is that too extreme to fly?
Mr._Torque is offline        Reply With Quote
Old 10-23-2010, 03:38 AM   #2
Bob O
Yes, that's too much. You really need a pitch gauge rather than just blindly making adjustments in the swash mix menu.
The value for swash mix ends up being whatever it is, and is directly related to any adjustment you made to it in order to get the pitch range you want. So if it defaults to 60%, and you measure your collective pitch at 10 degrees and you want 12 degrees just say. What you would do is increase the swash mix value until you get 12 degrees on the gauge. Whatever value you end up with in swash mix is what you end up with. Unless your swash to servo linkages are on the innermost hole on the servo arm, you shouldn't be anywhere near 125%.
Good luck.
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 10-23-2010, 07:28 AM   #3
silicosick
thanx for this info bob o .... gotta go check my setup...
Helis = Blade 400 • Blade SR • Blade 120SR • Blade MSR • Blade MCP X • Helimax Novus CP
Planks = Parkzone F4F Wildcat • Parkzone Extra 300 • Parkzone T28D • Parkzone Ultra Micro Trojan
silicosick is offline        Reply With Quote
Old 10-23-2010, 08:57 AM   #4
Larry227
and if you set your Aile/Elev swash mixes to 125% you will most likely cause severe binding in the head. Go here and watch the head setup videos.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
