Old 01-04-2007, 12:01 AM   #1
Wardy
Default (new) Z power 3300kv 450th is CRAP!!!!!
Just a note to all I recommend you don't purchase the (new) Z power 450th.
It is 3300kv and is blue and silver with a built in cooling fan at the bottom.
It does run very cool just warm to the touch but has not a lot of power compared to the stock Align 3550kv.
max head speed at hover with 225 woods .
11th pinion =2300-2400rpm
13th pinion =2500-2600rpm
align 3550 max head speed at hover 225 woods
11th pinion =2600-2700rpm
13th pinion =3050-3150rpm
outcome disappointment waist of money BUT might be good for a 4cell setup later .
WTF@freak'n heli.crash
Wardy is offline        Reply With Quote
Old 01-04-2007, 12:27 AM   #2
lowflyer101
I love the Z-power 1100 kv in my Logo. however i using Jgf 450 th and 450 F in my rexes.. over a year now.. never problem.. the 450F really powerfull motor .. with 11T and they shot into sky like rocket.
i don't if JGF and Z-power is ralated as thru their motor look very alike ???
lowflyer101 is offline        Reply With Quote
Old 01-04-2007, 04:54 AM   #3
Wardy
That is interesting lowflyer101,
What is the kv rating on the 450F and what head speed does it deliver at hover with the 11th pinion ? and what is the kv rating of the JGF 450th ?
I am still interested in a new motor in the middle price range and maybe even one with the 2mm shaft so it can go in my other heli if need be.
Does anyone know of a out runner motor on the market with a kv rating in the 4000 mark ? I am a believer of hi rpm with a small pinion to be a powerful combo .
Old 01-04-2007, 07:07 AM   #4
alex.venom
I have both: JGF 450TH and JGF 400DH.. both EXTREMELY POWERFULL, ligthweight and cool running motors... love both
400DH is rated 4400 KV and 450TH is rated 3000 KV.
"Every time Bob's vids are watched, a helifreak is born..."
by rdlohr
Crash Count:
Raptor 50 SE: 02
T-Rex 600CF: 01
T-Rex 450SE V1: 04
and progressing...
alex.venom is offline        Reply With Quote
Old 01-04-2007, 02:52 PM   #5
Boodlooder
Just a few things...
One, I think running such high head speeds is not recommended for wood blades anyways.
Also, you stepped down in Kv rating, so you should have expected some loss in overall head speed. That value is directly proportional to expected head speeds. Run your setup through a head speed calculator and you'll probably find that you're probably getting close to what you should be.
Also, I bet your amp draw has dropped a bit and you get better run times out of the packs too ?
The 13T drop seems excessive (450 RPM at best case) but the 11T head speed change looks pretty reasonable to me.
I have a JGF 450TH and only use a Pheonix 25A ESC and nothing gets warm except the ESC. (Of course I don't fly hard 3-D yet, but I can 'feel' the motor has plenty of power) It seems to me you might be dogging a product that is doing exactly what you're asking it to do. Maybe your choice of motors didn't match what it was you were setting out to achieve.
Why did you switch? failure? looking for more power?
HDX450
Superframe STK
HS-56HB x3 (cyclic)
HDX450 head (Align plastic grips)
Align 450XL stock tail mechanics
Futaba GY401 SMM/AVCS / HDS-577
CC P25 ESC
Futaba 6EXH / R146iP
JGF 450TH 13T pinion
Align 13C 2200mAh packs
Wanted: 1:18 Scale -
21st Century Huey Gunship Model
-or-
Motorworks CIA UH-1C Silver and Black
Boodlooder is offline        Reply With Quote
Old 01-04-2007, 02:57 PM   #6
lowflyer101
Wardy : go jgf site : www.justgofly.com they listed all info of motor there .. the 450f i use is 2.3mm shaft . i would recommend the 450th instead.. because 9-11T on 450F @ 2.9 - >3k hs could easy strip the maingear.. 450 th 13-15T sound bit more safe i guess
