Old 10-28-2010, 03:37 PM   #1
johnr3942
Default bad vibration during spool up and down
I just built my 500 3g and am experiencing a bad vibration about halfway through spool up and spool down. it only lasts for a second or two and then goes away. it does not vibrate during flight at all. Any suggestions?
T-Rex 5003g
T-Rex 700e 3g
johnr3942 is offline        Reply With Quote
Old 10-28-2010, 06:29 PM   #2
T/CHunter2009
Check blade tension, if there a bit too tight in the grips then you'll be getting some vibrations until they swing into place . Also re-check blade balance both main blades and tail.
Blade 130X : Bilnged out with Lynx & Microheli Metal ./ Batteries : Zippy Compact 500mAH / Glacier 450mAh /Eflight 300mAh iCharger 206B, P.S 350 power supply. Spin 8000kv motor.
T/CHunter2009 is offline        Reply With Quote
Old 10-28-2010, 07:35 PM   #3
ILoveMicroHelis
Is it a vibration or a shake?
If it is a shake it is pretty normal, and is often caused by to tight blades. If you tilt your heli to the side the main blades should stay straight but you should be able to "shake" them out of position.
Pete
ILoveMicroHelis is offline        Reply With Quote
Old 10-28-2010, 08:41 PM   #4
kouasupra
Check your feather shaft and main shaft. Even thought it looks straight it might not be.
kouasupra is offline        Reply With Quote
Old 10-29-2010, 01:03 AM   #5
johnr3942
I guess it is more of a shake than a vibration.
T-Rex 5003g
T-Rex 700e 3g
Old 10-29-2010, 03:21 AM   #6
scoti333
Yea could be main shaft if it's on spool down and spool up... BUT, I recently installed a 3G into my 500 and saw the same thing happening, however a couple of guys at my field said this is fairly normal for a 3G FBL setup? I've just now put a new main shaft on since I bought it used but haven't had the chance to fly it yet
-Goblin 700: Crashed but re-building, still needing electronics
-Goblin 630: CC Ice 120HV, vBar
scoti333 is offline        Reply With Quote
Old 10-29-2010, 06:01 AM   #7
im4711
Wow -> should not be caused by FBL system. I use MicroBeast and it does not shake during spool up. So blade tension sounds like a possible option as stated by some already. Also make sure you straighten out the blades OK.
If it is the main shaft I believe it might not stop that quick.
im4711 is offline        Reply With Quote
Old 10-29-2010, 07:42 AM   #8
dannylightning
mine shakes a bit when the blades are spinning at low RPM if its not shaking when the blades are at full speed you are probably ok depending on how bad the shake is..
Flying GAUI & Compass Helicopters,
youtube.com/dannylightning
facebook.com/dannylightning1313
dannylightning is online now        Reply With Quote
Old 10-29-2010, 08:55 AM   #9
Larry227
Mine will shake the odd time halfway during spool down if the collective is in just the right spot. Giving a little collective one way or the other usually smooths it out immediately. It's only happened 5 or 6 times all summer and just once since I went FBL last month.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
Old 10-29-2010, 10:09 AM   #10
dannylightning
i should mention that my friends 450 does the same thing. he does like tight blades tho..
Old 10-29-2010, 07:24 PM   #11
ualdrivr
IMO, barring any crashes and any bent shafts or other equipment on the heli, the main and/or tail grips are too tight on the blades.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 10-31-2010, 03:52 AM   #12
johnr3942
Problem fixed, I replaced the mainshaft and loosened the blades and problem went away. Thanks for all your help.
T-Rex 5003g
T-Rex 700e 3g
Old 10-31-2010, 04:06 AM   #13
ILoveMicroHelis
Was the main shaft bend?
Pete
