Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 11-01-2010, 12:47 PM   #1
kevinator9
Default 6HV Battery Compatibility
Following is a list of confirmed batteries that will fit in the 6HV with the canopy on. Thought I would try and make a neat and tidy list as the last topic to do this ended up needing the viewer to search and read through posts, hopefully will be able to make choosing and purchasing batteries easier. If there is anything you would like added (or changed if I have made a mistake) just post with that Brand, Capacity, Discharge Rate and Frames, and I will add to the list.
6HV Fly Bar Frames (All packs listed here will also work with 6HV FBL Frames and 6HV V2 Frames)
  • Blue LiPo 2650mAh 40C
  • Gens Ace 2600mAh 25C
  • Hyperion G3 2600mAh 35C
  • Hyperion G3 2950mAh 35C
  • Loong Max Tipple 3000mah 20c
  • ProTek RC 2500mAh 30C
  • ProTek RC 2500mAh 45C
  • Punch RC 2600mAh 35C
  • Punch RC 2600mAh 50C
  • Punch RC 3300mAh 35C
  • Punch RC 3300mAh 50C
  • Radien 2850mAh 30C
  • Spyder 3300mAh 30C
  • Thunder Power 2600mAh 25C
  • Turnigy 2200mAh 40C
  • Turnigy 2650mAh 20C
  • Turnigy 2650mAh 30C
  • Turnigy 2650mAh 35C
  • Turnigy 3000mAh 20C
  • Turnigy 3000mAh 30C
  • Turnigy Nano-Tech 2650mAh 25C
  • Turnigy Nano-Tech 3000mAh 25C
  • Turnigy Nano-Tech 3300mAh 25C
  • Voltz 3300mAh 35C
  • Zippy Flightmax 2650mAh 30C
  • Zippy Flightmax 2650mAh 40C
  • Zippy Flightmax 2800mAh 30C
  • Zippy Flightmax 3000mAh 20C
6HV FBL Frames Only (All batteries that are listed for the 6HV Fly Bar Frames will also work with 6HV FBL Frames)
  • Blue LiPo 3300mAh 30C
  • Chrome 3000mAh 35C
  • Desire Power 3300mAh 35C
  • Gens Ace 3300mAh 30C
  • Hyperion G3 3300mAh 35C
  • Pulse Ultra 3000mAh 45C
  • Pulse Ultra 3300mAh 35C
  • Sky LiPo 3000mAh 30C
  • Sky LiPo 3000mAh 40C
  • SLS EP 3300mAh 30C
  • SLS EP 3300mAh 35C
  • Thor 3300mAh 35C
  • Turnigy 3000mAh 35C
  • Turnigy 3000mAh 40C
  • Turnigy Nano-Tech 3300mAh 45C
  • Turnigy Nano-Tech 3300mAh 35C
  • Venom 3200mAh 30C
  • Zippy Compact 3700mAh 25C
  • Zippy Compact 4000mAh 25C
  • Zippy Flightmax 3000mAh 40C
  • Rhino 3700mAh 25C
6HV V2 Frame Only (All batteries that are listed for the 6HV Fly Bar Frames and the 6HV FBL Frames will also work with 6HV V2 Frames)
  • None Confirmed Yet
Andrew
kevinator9 is offline        Reply With Quote
Old 11-01-2010, 12:48 PM   #2
Ah Clem
Turnigy 3000 mah, 6S packs-fit properly only in the FBL frames.
Ah Clem is online now        Reply With Quote
Old 11-01-2010, 12:53 PM   #3
kevinator9
What C rating?
Andrew
Old 11-01-2010, 12:57 PM   #4
Ah Clem
Sorry, 35-45C Discharge
Old 11-01-2010, 01:05 PM   #5
kevinator9
Cheers RAK, it's added
Andrew
Old 11-01-2010, 01:56 PM   #6
alexmit
Blue Lipo 3300 30C packs fit the 6HV FBL frame.
alexmit is offline        Reply With Quote
Old 11-01-2010, 02:07 PM   #7
TheBum
Fantastic resource, Andrew! I'm just sorry I don't have anything to add.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 11-01-2010, 02:13 PM   #8
kevinator9
Added!
I already got your setup as I sneakily went through most of the 6HV battery topics and pulled what I could from them. So you infact did contribute!
If this gets good enough in your mind for a sticky would you like to do the honors?
Andrew
Old 11-01-2010, 02:38 PM   #9
TheBum
Just did.
Thanks for doing the legwork.
HeliFreak Support
Old 11-01-2010, 04:54 PM   #10
Dave Ketelhut
Flybar and FBL frames
Punch RC
2600 35C and 50C
3300 35C and 50C
Dave Ketelhut
Team Compass USA
Gens Ace
Prostarhobby.com
Dave Ketelhut is offline        Reply With Quote
Old 11-01-2010, 06:00 PM   #11
Greg B
The Voltz 3300 35C will also fit the flybar frames with room to spare. You have them down as fitting the FBL frame only.
Greg B is offline        Reply With Quote
Old 11-01-2010, 09:07 PM   #12
kevinator9
Punch RC
2600 35C and 50C
3300 35C and 50C
Done and Done!
Andrew
Old 11-01-2010, 09:37 PM   #13
feudallordcult
Hi Kevinator, many thanks for collating the list. I will upload some pics of turnigy 6s3000mah 30C in the FB version when I next visit the LHS. cheers!
Heli-ADDICTION:
E: Trex800, E-Aurora, X7F, E720, JR-E12, 550SX & 600esp (初恋)
Feeling of Hover at (28/12/2009) - PRICELESS!
feudallordcult is offline        Reply With Quote
Old 11-01-2010, 10:55 PM   #14
Rob43
Thanks mates. Also, I've not heard any mention of CG. is there room with Nano Tech 3000's to tweak for CG? I was thinking how nice it is once again to have an airfram unaffected by consumption of a pound of fuel from start to finish of a flight. I ran a rather big 3800 LiFe pack on my Fury 55 to get it right when the tank is half full.
= Rb43 =
Rob43 is offline        Reply With Quote
Old 11-01-2010, 11:13 PM   #15
jhheli
This is for FBL Frame, 6s 3000 40c zippy, 6s 3000 40c turnigy, 6s 3000 nano techs, 6s 3300 25c nano techs, these will all fit.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote
Old 11-01-2010, 11:14 PM   #16
kevinator9
CG changes from model to model as everyones layout is different. But the 3000 Nano-Techs allow for a decent amount of movement in the FBL Frames to compensate. (Which I assume you have?) I believe they are about the same size as the Turnigy 2650mAh 30C packs which is what I have and they can be moved a fair amount forward and aft.
Added!
Andrew
Old 11-01-2010, 11:21 PM   #17
TheBum
The 3000 25C Nano-Techs are longer but lighter than the 2650 30C Turnigys. There's certainly nothing wrong with the 2650s and it's hard to beat the price ($29 apiece plus shipping).
HeliFreak Support
Old 11-02-2010, 12:04 PM   #18
Rob43
I do have te FBL model with "notched" frames. Where is the limitation in pack size? Length - nose, or width?
= Rb43 =
Old 11-02-2010, 01:18 PM   #19
kevinator9
The maximum dimensions are almost impossible to calculate (unless somone here is good with three dimensional conics).
This is because as the length on the battery pack changes, the allowed height/width of the pack changes as the shape of the canopy curves down.
So for a longer pack it will need to be not so tall and/or fat and for a shorter pack it can be taller and/or fatter.
Andrew
Old 11-02-2010, 02:15 PM   #20
TheBum
Andrew hit the nail on the head. I asked the same question before I got my 6HV and nobody could give me a definitive answer.
For some packs, they may fit when turned one way and not fit when turned 90 degrees.
HeliFreak Support
