Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 6HV
Atom 6HV Compass Atom 6HV Model Helicopter Discussion
Old 11-03-2010, 02:57 PM   #21
alexmit
Originally Posted by Rob43 View Post
I do have te FBL model with "notched" frames. Where is the limitation in pack size? Length - nose, or width?
Whether you are using FB or FBL, you can very easily check to see if a pack fits. Cut cardboard or any other rigid material to the dimensions of the pack in question and tape it together to see if it fits under the canopy. If you want to be real fancy you can fill them with sand or weights to see if the CG works out too. But that means evenly distributing the weight inside your "fake" cardboard battery or batteries in the case of the 6hv.
Almost every manufacturer states the weight and dimensions of their packs.
alexmit is offline        Reply With Quote
Old 11-10-2010, 10:21 AM   #22
feudallordcult
Default Advice needed on next purchase
hi folks, i m really keen on getting 10 packs of this lipo cos its really cheap. any advice why I should not buy this other than the fact that its only 20C. I dun do hard 3d, only loops and forward flights. I got 10 packs of the 3000mah 30c which are heavier but its for the rex600. thanks in advance for advice.
Trex700N LE, Trex600ESP,Mini-Titan & Trex250SE
Feeling of Hover at (28/12/2009) - PRICELESS!
Biggest mistake - selling my Beam...crap!
feudallordcult is online now        Reply With Quote
Old 11-10-2010, 10:36 AM   #23
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
30C is better, especially at that lower capacity. Last I checked, the 2650 30C regular Turnigys were $29, still cheap. I have 7 of the 30C packs, 6 paired up for my 6HV, and they work well.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is offline        Reply With Quote
Old 11-10-2010, 01:33 PM   #24
flyingkiwi
As per Bum, I am using the same 30c and they work very well. But, I must admit I have just bought 4 of the nano tech's to try out.
Kasama 90n, cgy750.
Gaui X7, X5, cgy750, Hobbycity
Compass 3d plus
Futaba 14sg.
flyingkiwi is online now        Reply With Quote
Old 11-10-2010, 04:21 PM   #25
iadamz@mac.com
I currently have six of the Nano 2650 35c for my Protos but want some good cheap packs for the 6HV which I can use between them, What about the Turnigy 3000 20Cs, Seems like they might be the best if you don't try and squeeze out anything past 430 to 5min... I figure 12 packs total would mean 12 flights on the Protos or 6 Flights on the Compass and any combination in between
As for the Turnigy 2650 20C you linked to they are fantastic, Had ten of them and after I learned how to take care of them, meaning 4 minutes of whatever type flying on my Protos and then land, they last a long long time.
Not sure about this whole series thing though....is there a special way to plug everything in, sometimes I see videos where it seems like folks are plugging in the leads to the Esc one at a time? or the leads are at least separated?
I was going to make or buy something like below, where are details on how to wire in the anti spark wiring one the Hobbywing black lead? Is there a reason for plugging them in one at a time?
Flying a MSHeli Protos 500 - - 3DHS Velox Vr1 for plank flying - Leadfeather Yakk 55 for crashing.....All controlled by an Aurora 9
iadamz@mac.com is offline        Reply With Quote
Old 11-10-2010, 04:35 PM   #26
TheBum
Originally Posted by iadamz@mac.com View Post
Not sure about this whole series thing though....is there a special way to plug everything in, sometimes I see videos where it seems like folks are plugging in the leads to the Esc one at a time? or the leads are at least separated.
This is not really the place to discuss the connections themselves, just the batteries. This thread will show you how I did mine:
http://www.helifreak.com/showthread.php?t=248914
If you want to continue the discussion, you can post in that thread or start a new thread.
HeliFreak Support
Old 11-10-2010, 05:05 PM   #27
Big Choppa
Will the Turnigy 3000mAh 30c fit the FBL frames?
Big Choppa is offline        Reply With Quote
Old 11-12-2010, 02:59 AM   #28
feudallordcult
anyone else flying the 2650 20c pls share yr experience.
it's quite frustrating to wait for hk to replenish stock of the 30c. as for the 3000mah 20c that's selling for abt 33, pardon me for my ignorance but 13 bucks for additional 350mah at the same 20C doesn't quite work it for me. I could be wrong to view this issue, anyone with differing opinion pls correct me. thank you.
Old 11-12-2010, 11:25 AM   #29
Cullen Colapietro
I've flown the 2650 20Cs. If you're not running a crazy HS, you'll be more than happy with those batteries. Just get them, if they don't suit you, you can always sell them for a decent return on your investment.
My opinion.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD
Cullen Colapietro is online now        Reply With Quote
Old 11-30-2010, 07:16 PM   #30
AnTi Taco
deleted
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote
Old 11-30-2010, 07:18 PM   #31
AnTi Taco
Originally Posted by jhheli View Post
This is for FBL Frame, 6s 3000 40c zippy, 6s 3000 40c turnigy, 6s 3000 nano techs, 6s 3300 25c nano techs, these will all fit.
i got the 6s zippy 3000mah 40c and i can't get my 6HV canopy on
Old 11-30-2010, 07:29 PM   #32
Cullen Colapietro
Hmm,
this is in conflict with post #1
have you tried balancing electronics so that you can fit these batteries in your FBL frames? Seems they should fit as per others' findings...
Hopefully you can make 'em go.
Old 11-30-2010, 07:36 PM   #33
AnTi Taco
i pushed the lipos as far back as they go right up against the frame and im a half inch away from the canopy mounts dont want to push on the canopy anymore afraid it might crack it
BUT.. maybe its not fitting cause my kits not together yet just got it today and strapped the lipos to the frame and tried to put canopy on but it was a no go
Old 11-30-2010, 07:43 PM   #34
Cullen Colapietro
Hopefully someone with those batteries can comment?
Old 11-30-2010, 07:49 PM   #35
AnTi Taco
yeah once my kit is fully built ill know 100% if they will fit but as of now with just the frame out of the box with the canopy i had no luck getting them to fit
Old 11-30-2010, 08:20 PM   #36
TheBum
This may be a silly question, but did you try the packs in both orientations. They may not have a perfectly square cross-section.
HeliFreak Support
Old 11-30-2010, 08:25 PM   #37
AnTi Taco
did side by side with labels facing up... and tried bottom to bottom like in the photo above
Old 11-30-2010, 11:35 PM   #38
AnTi Taco
ok my choice of packs are the ones listed below.. my first choice is the 3300mah pack but what im concerned about is the C rating of only 25c .....out of these lipos what what you get? disregard the Mah i know ill get shorter flights times with the 2650..... just want to get the packs with the most kick but not sure if C rating matters much with 12s in series
Turnigy nano-tech 2650 6S 35~70C Lipo Pack
Turnigy nano-tech 3300mah 6S 25~50C Lipo Pack
Old 11-30-2010, 11:50 PM   #39
TheBum
3300mAh 25C is plenty for this heli. If you were planning to share packs with a 500, you'd probably want to go to a higher C rating.
HeliFreak Support
Old 11-30-2010, 11:52 PM   #40
AnTi Taco
