| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I dont know if this has been done yet but I just figured this would be a good thread to show off your wiring and get some ideas.
Do you follow the align electronic placement or you just go by what you feel like. Also any tips would be awesome Gill P
Gill P. SAB Goblin 700. SAB Goblin 500. JR X9303 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
a little of both, I have built several helis already so I read and weigh what the manual says and do what I think is best.
Carl Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544 |
I look at what the manual suggests, and then ignore it.
I try to get everything inside the frame (plenty of room for everything on the 550). I don't like to strap things to the outside of the frame.
Trex 450 sport Radikal G30 - Hanson G26 3D max |
Heres some pics of mine.
I used to hide everything, but now i mostly try to run the wiring outer so its a heap easier to repair, and servos can easily have their gearset changed without having to unplug and undo all the wiring. I also use nitto automotive electrical tape, or 3m, saves braiding and insulates and helps stop general (not genital) chaffing. A good tip is try not to run wires where it makes removing the boom box or other parts difficult, when the helis easily serviced and repaired it makes crashes and fixups so much less of a drama. Cheers Col. |
Here is some of my wiring. It may look like some wire are resting on the frame edges but rest assured they are not touching. Feel free to critique me
Gill P
#6 |
I can't, because 90% of it is hidden inside the frames and covered in heat shrink. But the ESC is on the side. |
#7 |
Col, I see where you are going but to me that is not the way to do it, keep wires on the inside but keep them visible for inspection.
#8 |
]The best organized setup i've ever reached with those big Vbar parts:
![]() ![]() 99 precent of building that was thinking.... |
#9 |
Looks a little crowded
#10 |
"Sort your head out and fly with your heart" Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc, Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251 |
#11 |
Sniff....Sniff.....Sniff I smell some Jive
#12 |
Yep it's pretty quick thanks, keeps me smiling
#13 |
Here are a few pix of my 550 wiring scheme.
T-Rex 800e DFC Trekker w/VBar, Blades MCX2, 120SR, Radian Pro, DX8's. |
#14 |
Swwwwweeet Job I hope u dont mind im going to follow !
Just waiting for my AR7200BX to be released to finish it YEA !!!
Dx7,T-550Ev2,T-450 pro Dfc, 130 X, mcpX BL Brushless Nano RUSH 750 being built To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 |
Few of mine.
Wynn
T-Rex 550 FBL rcparts-finder.com...an online database to find your parts in stock at various online stores... |
