| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I know it's not a Pro-specific question, but... do you guys keep the throttle trim all the way down? This is how I was told to do, so both my simulator controller and my coaxial radio are currently setup this way.
With the Pro and the Futaba 7C (first radio I have with digital trims) I totally forgot, but I don't seem to have any problems... I never understood why throttle trim should be all the way down... could someone explain?
Align T-Rex 450 Pro Super Combo, Futaba T7C 2.4GHz Esky KOB 2.4GHz |
I think only on Nitro helis do you have to keep the trim all the way down.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
I keep all trims on my radio at zero.
Kris |
Good, thank you guys.
All my trims are centered, except for the throttle one, if I connect my heli with the trim up, it won't bind. It get it as throttle up.
#6 |
Well... did you calibrate the ESC with the trim centered, or down? If you did the calibration with the trim down, of course you will have to keep it that way when you connect the battery, otherwise the ESC will think your throttle stick is not at zero...
#7 |
^^ exactly.
On my 7C all trims are centered. Calibrated the ESC and done with it. On the RTF kits with simple TX, the throttle trim is always down for the ESC to arm. In other words the ESC needs to see an absolute zero to arm.
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75 TSH Gaui X5 FES, Microbeast v3, S.Bus, DS610s, DS650, YGE 100LV Futaba T7C Phoenix R/C v4 |
#8 |
I programmed the ESC with the trims downs. i'm not sure but I thought I read about it, or that the way I learned, I don't see ill behavior. now the interesting part would be if there's and advantage programming the ESC with trims down vs. centered.
#9 |
It's interesting to see that people do things differently, although I really can't understand what's the advantage of keeping the throttle trim all the way down, particularly on an electric collective-pitch helicopter.
If someone knows, please explain it to the masses...
#10 |
If I had to generalize I'd say that if your ESC is programmable then your throttle trim should be centered. Most ESC's are and therefore you should center the trim. This is also important in order for TH and throttle cut to work correctly.
If you can not program the ESC then you may have to bring the trim down so that low throttle is recognized.
#11 | |
#12 | |
Read the instructions with your given ESC....that is what a person should do.
#13 |
I see your point, I'm still fairly new to Heli, only 10 months into the hobby, Have been thru 4 Heli, 2 E-sky and my first builds are my current T-rex 600 and 450Pro. So basically I'm still with the stock Align ESC's, I believe that the E-sky manual stated the trim down, don't have it anymore so can't check, I think that's where I got the idea of trim down. I'm thinking on getting a phoenix ice, so good to hear CC are different.
#14 |
I have an Castle creations ice 50 and I either have to put trim all the way down or use the throttle hold switch to get it to arm.
#15 | |
See bottom of page for adjustment instructions: http://www.castlecreations.com/support/documents.html
#16 | |
It should see closed throttle based on endpoint on the low end. If you have to trim down something is wrong with the setup..... Make sure you have a linear throttle curve in normal mode when setting endpoints or it drives the CC software nuts. After setup you can return your normal curve to how you like to have it.....
"It's not the crash so much as the sudden stop" Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, Blade MCPX, bunch of other junk in boxes |
