| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
my kit has both 16 and 17 tooth pinions, i am running the 16 but was wondering if the 17 will work better with the stock set up.
stock servos stock motor stock esc spartain quark gyro stock blades hyperion 5000mAh 35c 6s pack spectrum ar60000 reciver opinions please |
Running the 17t will give you a higher headspeed but at the cost of flight time.
Unless you're a stick banger stick with the 16t.
Trex 450 Pro V2 FB spartan quark trex 250 beastx Fusion 50 beastX |
#3 | ||
Zen and the Art of Helicopter Maintenance Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
17t is ok with the stock blades but will cut the flight time a little. Don’t use 17t if you go to longer blades or you may blow the ESC but it’s ok with the stock 520mm blades.
Yikes. Please do not use a parkflyer receiver for your 550!
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e HeliDirect, Team iKon, GrandRC |
