Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-15-2010, 08:45 PM   #1
mickshalldale@yahoo.com
Default recomended BEC and pack for 550mm blades and 16 thooth pinion/stock esc
i have the stock esc running hyperion 5000 35c, i recently got 550mm blades with the 16 tooth pinion. i strecked the boom the 600 and but 95mm tail blades.
i worry about my esc overheating so i wanted to get a bec.
i dont really know what to get or how to use one because i have never had one before.
do i even need one ??
oppinions please
mickshalldale@yahoo.com is offline        Reply With Quote
Old 11-15-2010, 08:51 PM   #2
Blades345
oppinions please
You would be wise to get one. I have one on my Trex 550 with my Mini Vbar. I am running the CC PRO BEC. Its about $38 bucks and its worth it. My stock ESC doesn't get hot at all.
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!!
No helis right now!
Maybe I'll be back in another year!
Blades345 is offline        Reply With Quote
Old 11-15-2010, 08:58 PM   #3
Wolfpackin
The way I understand it the BEC only effects voltage and current going to the servo's and gyro. So, getting an external BEC will not help an overheating ESC due to increased current draw from a motor with bigger blades.
For that I think you just need a better ESC, one that can handle higher amp draw.
Please correct me if I'm wrong...not strong on electronics here.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 11-15-2010, 09:45 PM   #4
Blades345
I believe you are correct, but I was merely stating that the stock ESC with the 550mm blades is fine and it won't overheat. I fly 3D and put some decent stress on the ESC and it stays warm, but never gets hot. I would recommend running a separate BEC though, just in case the internal BEC in the ESC failed.
No helis right now!
Old 11-17-2010, 05:04 PM   #5
LARRY2716
A linear. BEC converts excess voltage to heat. A standalone BEC will make ESC run cooler.I use Western Robotic Mini 10 amp contact 16 peak. Nice and light, though expensive.
LARRY2716 is offline        Reply With Quote
Old 11-17-2010, 05:55 PM   #6
Ah Clem
I would use a stand alone BEC also-I have been running the WR Hercules (four in service) and the Mini Hercules (1 in service) and am very impressed, so far.
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
