Old 11-29-2010, 03:08 PM   #21
CoolKD
Originally Posted by crashandburnagain View Post
oh, ok im sorry i guess i misread your reply. I was thinking at least going for some thing with metal gears being i have to order something anyway. an hs65 is like 30 and the jr i think 290 is almost the same. So if i could get better for the same without have to add a bec at this time i would rather go that way if i could
A HS65 is not a good tail servo, it's more for cyclic use. Try the Align DS520, it's a fast good digital servo for the tail.
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro. KDE FBL Head & BatTray,MKS DS95,FutabaBLS257,BeastX, ICE50, CC BEC, Scorpion6
Align Trex700LE N. LYNX Clush/Liner, Quark,Hatori SB20FH-2,O.S91HZ
CoolKD is offline        Reply With Quote
Old 11-29-2010, 03:27 PM   #22
Cailid
You don't need metal gears for the tail servo. They're better for the cyclics. I doubt you'd need a bec just for the tail servo either.
MCX, CX2, MSR
Blade 400, 500ESP, 500CF
Cailid is online now        Reply With Quote
Old 11-29-2010, 03:50 PM   #23
Dazhim
As was said the stock servo by stats is better then whats there.. IDK if you are still using the stock cyclic servos but I found a guy selling all r stockers for 10 bux
http://helifreak.com/showthread.php?t=259588
Might b worth checkin out for a min then u can save for a proper tail and have spares to boot.
and the 290 is a decent tail servo for the price. I am assuming(know i shouldnt) that u want to b able to mount it in the stock location yes?
Dx7s, 450 pro fbl,hs65mg,savox sh1357 BeastX
Big Rexy 600 R.I.P(rest in pieces)
MSH Prôtos: 500 fbl
IKON baaaby
mcpx real life SIM
Dazhim is offline        Reply With Quote
Old 11-29-2010, 03:54 PM   #24
crashandburnagain
yes i would like an easy fit replacement. I would rather go for the better up front, thats not a problem i just dont want to have to go for a bec right now if i dont have to. i will go for a jr if its plug & play with no bec, thats fine. When the time comes for gyro, would that require the bec or not?
crashandburnagain is offline        Reply With Quote
Old 11-29-2010, 04:00 PM   #25
Cailid
Needing a bec will vary with each heli. If your esc is getting too hot to touch then it's time for a bec or a better esc. I was able to upgrade my gyro and servos without needing a bec or new esc but some people needed one as soon as they started any upgrading.
MCX, CX2, MSR
Old 11-29-2010, 04:10 PM   #26
crashandburnagain
well i think that kind of sounds like what i want to hear. First will be jr tail servo then prob. hs 65 for cyclic, then when it dies or i have the money ill do the gyro.
Old 11-29-2010, 04:31 PM   #27
Dazhim
Crash.. I think Most people lean on the side of insurance because we know what will happen to eflites esc.. some take chances.. I had installed the hs 65 hb's 1st then the 290.. and my esc ddnt get warm until i put the gyro on.. since then i have changed the esc all together but still use a bec just in case.
Airflow IMO is key hovering has very little air movment passing over the esc and components not to mention the canopy has no flow holes liek the align ones. Ok I'm rambling.. there are alot of options my friend looks like research is gonna be your best way to go but i understand this thread tryin to b a shortcut.
MSH Prôtos: 500 fbl
IKON baaaby
mcpx real life SIM
Old 11-29-2010, 06:14 PM   #28
crashandburnagain
I think you pretty much sumed it for in a nutshell. Thanks alot.
Old 11-29-2010, 10:23 PM   #29
Avidflyer
I think the biggest benefit of a BEC is if the speed controller cooks or shuts down for any reason you can still control your heli and at least have a chance at landing.
Blade 400 Hughes 500 Scale
Align 450 ProV2 3GX V2.1 450 Sport FB aka "The Beater"
Raptor 50 V2 OS50SX-H "Ol Faithful"
Align 700N LE BeastX
Avidflyer is offline        Reply With Quote
