Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-21-2010, 10:45 AM   #1
QYT001
Default Carbon Tail Control Rod?
What is advantage of Carbon Tail Control Rod?
http://www.align.com.tw/shop/product...oducts_id=3681
T-Rex 700N: JR DS8717HV; Vbar 5.3+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG; OS MAX 91HZ-R
T-Rex 700E: JR DS8717HV; Spartan Quark + Outrage BL9188HV; CC ICE HV 160A; RCM-BL700MX (470KV); WR Super BEC
T-Rex 250SE 350Watts
QYT001 is offline        Reply With Quote
Old 11-21-2010, 10:55 AM   #2
QYT001
Also there is one from QuickUK
Trex 700 - 3D Tailboom Clamp & Pushrod Guide
http://www.quickuk.eu/products/1584/...e_tx7t-22.html
Trex 700 Carbon Tail Pushrod
https://www.quickuk.eu/php/index.php...w=1585&preview
Trex 700 Replacement Tail Pushrod Ends
https://www.quickuk.eu/php/index.php...w=1588&preview
Old 11-21-2010, 11:38 AM   #3
backburner1955
The advantage is that you will get a more accurate tail, less flex in the pushrod.
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Reply With Quote
Old 11-21-2010, 08:05 PM   #4
ualdrivr
I like the Align one, any idea when it's going to be available? Anyone?
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 11-23-2010, 10:36 AM   #5
jstarks
Will this work on the 700N or just the 700E?
http://www.helidirect.com/align-alum...pro-p-7927.hdx
The diminsions for the stock control rod for the 700N say that it is 778mm.
The dimensions for the carbon control rod say that it is 760mm.
18mm is quite a bit shorter. Is the bell crank farther back on a 700E?
I would love to run this on my 700N but I dont think it will work. Has anyone tried it on a nitro?
J.
700LE Vbar-YS91SR, SB-19 / 700LE Beastx-OS91HZ non-pumped, SB-20 / Henseleit TDR-Vbar, Jive 120/Pyro 700-52, 8917/9188 / Logo 600 SE-Vbar, 12s, 4035-3Y, Jive 120HV / Logo 600 3D-Vbar, 12s, 4030-3Y, Jive 80HV / Compass 3D+-Beastx, YS56, Outrage H56
jstarks is offline        Reply With Quote
Old 11-23-2010, 11:28 AM   #6
J-S-Q
J.
My guess is that the 760mm does not include the extra threaded rod at each end of the carbon rod hence the reason why it is shorter than the stock metal push rod. It's only a guess though.
J-S-Q is offline        Reply With Quote
Old 11-24-2010, 08:48 PM   #7
backburner1955
According to the Align Manuals, both the 700E and 700N use a 778mm rudder pushrod, so I would assume that the 760mm length measurement on Aligns site represents the length of the carbon rod, not counting the aluminum ends.
I am going to get my LHS to bring one in, well a few, some other guys want it too. I will compare the lengths and report back. I dont think he will be able to order until next week, but it looks like it is available.
I like the Blue and white F3C tail fins in the pic too.
Bryan AMA# 982814
"No-Neck R/C"
