Go Back   HeliFreak > R/C Batteries and Charging Support > A123
A123 A123 Battery Support
Old 01-10-2007, 06:30 AM   #1
Cryofix
HeliFreak Security Staff
Default A123 and TP210
Not sure this is all TP210's and A123 stuff but for my stuff I am having a problem with the TP 210 bleeding off almost 170 mAh!
After a full charge and a finished balance I drop my A123's back on the charger and get back between 79 and 170 mAh more back into the pack, if you fly A123 and run them to the limits even 80 mAh may save you from a forced auto.
this is just a heads up for the people who time their flights, don't push your max time without knowing your pack is topped off.
MSH Protos FBL SK720
Trex 600 14S A123 CCHV110 Actro 24-3
Trex 600 AP 12S A123 CCHV85 NEU 1912 1y
Gaui 200
Trex 450 SE V2 Dedicated night Rig
Cryofix is offline        Reply With Quote
Old 01-10-2007, 11:03 AM   #2
GGoodrum
Yes, I've seen the same thing. If I have time, I usually stick it back on the charger and top it off, using a low current setting, like 0.5A.
-- Gary
-- Gary
www.tppacks.com
GGoodrum is offline        Reply With Quote
Old 01-11-2007, 01:50 AM   #3
Cryofix
Just got in my 2 PB-6 balancers today, gonna try them out tomorrow, the thing i love the most is being able to see individual voltages per cell with these this way I know when or how close I am to balanced.
Gaui 200
Old 01-11-2007, 02:19 AM   #4
spork
Cryofix,
What are these PB-6 balancers you speak of? I just got some A123's and am thinking of picking up a Cell-Pro balancer/charger. Is there something better?
Nothing is ever as good or as bad as it seems.
spork is offline        Reply With Quote
Old 01-11-2007, 08:27 AM   #5
rerazor
http://www.rcaccessory.com/index.asp...ROD&ProdID=191
Robert - DJIUSA.com
N. A. Dist. for DJI Innovations
USA Dist. for Photohigher
USA Dist. for Vario (Industrial)
rerazor is offline        Reply With Quote
Old 01-11-2007, 09:50 AM   #6
spork
Thanks for the link. I don't see the voltage per cell display Cryofix is talking about. Sounds like a nice feature. Does that require additional hardware?
Old 01-11-2007, 10:28 AM   #7
dreslism
Why don't you look at individual cells with your TP1010c/210 combo?
I do.
dreslism is offline        Reply With Quote
