Belt CP E-Sky Belt CP
Old 11-27-2010, 07:46 AM   #1
ReadyToCrash
Default 12t pinion on a belt v2
hi,
i'm using a hobbymate 2835 motor with a 12 t pinion.
i wonder whether it is ok for a belt v2 or whether i should use a 10t pinion.
thanks.
ReadyToCrash is offline        Reply With Quote
Old 11-27-2010, 08:11 AM   #2
redbird300
Originally Posted by ReadyToCrash View Post
hi,
thanks.
12t and that motor is too much for the Belt, IMHO. Would be OK on a full metal 450 though. Better stick to the 10t pinion.
TDR - Logo 600SE + 500SE + 400 - Furion 450 6S mini-V - 300X - 2 x mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner
FAI world record longest electric RC heli flight: 1h 46m 22s
redbird300 is online now        Reply With Quote
Old 11-27-2010, 08:13 AM   #3
ReadyToCrash
hi,
could you tell me how to get this calculator?
thanks
Old 11-27-2010, 08:16 AM   #4
redbird300
hi,
thanks
Very simple, just click my signature, lol.
Old 11-27-2010, 08:23 AM   #5
ReadyToCrash
hey,
thanks a lot.
what is the good rpm for a belt v2?
thanks.
Old 11-27-2010, 09:01 AM   #6
redbird300
hey,
thanks a lot.
thanks.
mid 2000's or slightly above should be OK.
Old 11-27-2010, 02:11 PM   #7
dayshaddow
hay redbird great tool ive just downloaded it as i was asking about a pinion for my motor around a week ago and followed your advice
anyways after getting your HS tool i looked into my motor specs just for a lauf..do you think you can look over this link and tell me what you think
http://www.hobbycity.com/hobbycity/s...0kv_(450_class)
my motor is a Turnigy Typhoon 2218H
im using a 150 tooth align main gear
and an 11 tooth pinion thinking of upping to 13 pending your thorts
on a HK450 SOON TO BE ALL CARBON blades,frame,paddles,tail blades and poss boom
so the test flights was awesome and in 20 mph winds using a 2800mah lipo,rock solid flight i was pooping my pants as i havnt flown in a few months but came home very happy with my new bird.had to stop after two flight as i was freezing my nuts off so had to pop the other 4 pack back on storage till spring arrives
thanks for your time and HS tool
antony
msr msrx tr250 hk450
2 planks
wat for foamy and eflite beast
1/8th Brushless LiPo Powered monster Truck
dayshaddow is offline        Reply With Quote
Old 11-27-2010, 02:23 PM   #8
redbird300
antony
If you do the calculations, you'll find about 2450 RPM for the 11t pinion, and about 2900 RPM for the 13t pinion, with your setup.
2450 RPM sounds a little low on that heli, but should still be pretty much OK for sportsflying and long flying times, but you might like the extra stability and punch with a higher headspeed, it's a very personal thing. I would go for the 13t pinion, but that's just me.
Old 11-28-2010, 02:22 AM   #9
dayshaddow
thanks redbird
im a scale flyer so found the two flights ok..but i did a stall turn and found the low head speed to be a tad scary as the ground got to close for my likings.im off to get me a 13 tooth pinion
cheers
antony
2 planks
