Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 12-27-2010, 05:12 PM   #21
AnthonyJr
Turned out pretty good. The cracks look good, the tears look good, and the scales have great depth.
Great job and keep them coming
GrandRc
AnthonyJr is offline        Reply With Quote
Old 12-29-2010, 12:20 PM   #22
Diviner
Default Seventh Canopy: Trex 600 Blue Flames "Fire & Ice"
Objectives
  • Flame Design
  • Large Logo spanning over different areas
What worked
  • Flames. Pretty easy all things considered.
  • Gunmetal black vs straight black.
  • Overall Design. Design elements + flames not getting in each others way.
  • Not putting on a third knock back flame color. 2 plus white accents was enough.
What didn't
  • Too many flames cluttered the design
  • Lifting of gunmetal when doing Logo
  • Flames needed to be more at an angle to create a sense of motion
After watching true flames videos I went with the blue flames. In summary:
1) base white for heat source
2) template white and free hand for softening near tips
3) Push back with a candy color
4) repeat 2 (or more) times varying color on the third time.
5) Fill with black to hide mistakes
6) Accent with final white.
Step 1) Templates & Paint
Started by googling "true flame templates" and found public domain flame set. Cut them out of card stock. Well, I didn't have any candy color so I used semi opaque process blue and transparent deep blue (didn't use purple pearl for flames even though I intended to).
Step 2) Practice > Layer 1
Shooting on black paper.
(L) White with template and freehand
(M) Push back with process blue
(R) Starting with 2nd layer of white
Step 3) Practice > Layer 2
(L) Pushing with 2nd round of semi opaque process blue.
(M) Pushed with transparent deep blue (didn't add another layer of white)
(R) I didn't like any of the templates. Not enough gullets so I made my own of different sizes.
Step 4) Taping and first bands.
The theme was fire and ice so I need to get red in there somehow. After it was taped up it had a batman look (L). I kept the lower front free from design elements and planned for the windshield to be dark so the flames could pop. I did some basic whisps on the lower area (M) and did a stepped gradient on the top blue band (R).
Step 5) Rest of the Canopy base.
(L) Purple windshield with diviner logo (just like I did 250 Moxy).
(M) Waiting for field area. I chose to add black to metallic silver rather than go just black.
(R) The white pins were too strong against the dark colors so I pushed them back with transparent black when I was putting on the corner accents. In retrospect I don't think this was needed since the multiple coats of flames knocked them back.
Step 6) Flames Layer 1
(L) White dusting at flame source + freehand (a little sloppy)
(M) Template white work + freehand tips.
(R) Blue wash coat. Layer 1 done.
Step 7) Layer 2
(L) Repeat white and deep blue wash. 2nd layer done. I stopped at the second layer as it was already too busy.
(M) I went back with black to create more negative space.
(R) Final white accents. A bit sloppy.
Step 8) Logo
(L) Mask over transparent medium sealer (not enough however).
(M) Lifting. I ran out of medium and didn't bother to refill the the cup (too lazy). I thought there was enough coverage. I didn't take into account the mask size. Plus the blue tape is more sticky which I needed so I wouldn't get leaching.
(R) I thinned the white too much and didn't press the tape down enough because I was afraid of lifting. I repaired it with a Qtip passing a paint brush.
COMPLETED PHOTOS
ID:	197809   Click image for larger version
ID:	197810   Click image for larger version
ID:	197811   Click image for larger version
ID:	197812   Click image for larger version
ID:	197814   Click image for larger version
ID:	197815   Click image for larger version
ID:	197816   Click image for larger version
ID:	197817   Click image for larger version
6hv, 6hv, 7hv, X5, T500, Warp, 300x powered by the FLUX CAPACITOR
Diviner is offline        Reply With Quote
Old 12-29-2010, 12:23 PM   #23
Diviner
Default All 7 "One Off" Canopies.
The journey is nearing the end.
Just 2 more posts left . . .
Old 02-17-2011, 10:43 AM   #24
Diviner
Default Journey is Complete! 12 canopies finally done.
Here is the fleet.
and a detail shot
Final words of wisdom.
1) To avoid lifting use transfer tape (lightest tack as possible). I bought it from Beacon Graphics. Masking tape has too much tack.
2) When locking down layers with transparent, let it dry overnight. Even at 4 hours of dry time I still had lifting.
3) .2mm tip is too small. It got clogged too often.
Hope this helps someone in the future.
ID:	208826   Click image for larger version
Name:	Fleet-Detail - small.JPG
Old 03-02-2011, 09:09 PM   #25
amcutem
You skills and patient make me sick. nice work
amcutem is offline        Reply With Quote
