| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
#41 |
Thanks guys, I did get V3 installed from my Mac (OS10.6.8).
Of course a simple readme would have been nice from BeastX. But for any Mac guys, at the risk of repeating (it is similar to the Windows install), what I did was go to http://beastx.com/service_software.html 1) Download anyone of the three Firmware version 3.0 (doesn't matter which one, the Mac will expand any compressed file into the xxx.upd version. 2) Download from the third section the BeastX Update Bundle for Mac. This will make a BeastXSoftwareBundle.dmg to your download folder. It may selfmount on the desktop, but I had to double click it. 3) Drag (as it shows) the BeastXUpdater.app to the Applications folder. 4) Then double click the SiLabsUSBDriverDisk.dmg. This will open another mounted disk image. You can read the releaseNotes, but basically just double click the "Silicon Labs USB Driver Installer.mpkg" icon. This will launch an installer for the USB dongle. Just follow the directions (I just chose all the default choices), but you will have to reboot after it installs. 5) once it reboots, then go to the application folder and launch the BeastXUpdater.app. 6) Plug in the Dongle to a USB port, and then select the USB port in the top drop down menu. 7) Then I connected the microBeast to the dongle cable (system port on microBeast), and put in a standard receiver battery into the "ELE" port. This lit up the lights on the microBeast (this was all new to me as mine just came yesterday and was fresh out of the box (with V2 firmware). In the lower section of the BeastX Updater window, I clicked refresh, and saw that the microBeast version showed up--a little confidence building, as it meant I was talking to the microBeast. 8) The in the middle section, I clicked the Open File button, and navigated to the firmware file I downloaded in (1). The section then shows the app and data version. You should see 1.X for the Target Hardware version, 3.0 for the Application version, and 6.1 for the data version (obviously these will be different when newer versions come out!). 9) Hit the "Start update" at the bottom. When it finishes, hit the "Refresh" button, and you should see the Application version now 3.0! Congratulations---you did it. Now I am not sure what the Micro Settings download is (between the firmware and the upload app). According to the Web page, you can't set settings yet with v3.0, but here it is. I opened it up, but didn't try to do anything with it. |
#42 |
Just updated my BeastX. I could not get updater to see my BeastX until I....
Powered up BeastX with a reciever pack with USB iterface connected to the Heli.. Then when I plugged USB into PC,, autodetected and updated.. Hope this helps somone..
AMA # 927862 Trex 500 FBL esp Kontronik Jive 80LV / Scorpion 1600kv - JR 3517mg cyclic - BeastX / Futaba BLS 257- Compass Tracx FBL head JR9303tx / AR7600rx |
#43 | |
Suat Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | BeastX | GV-1 | Stock Zenoah G290RC | Century V5 muffler |
#44 |
I did the similar steps excepted no connection to any heli, just RX pack to BeastX and then USB between laptop (XP) and Beast X. USB was auto-detected by XP and update without any issue.
Ching-Ho Cheng Hirobo Quark - Aluminium rotor head and swashplate upgrade T-Rex 450 Pro, zyx-s, T-Rex 250 SE, BeastX, DFC head, Warp 360, Scorpion 1360KV |
#45 |
Updated using wall and lcc014's way.
Thanks.
#46 |
i keep getting a error insufficent priviliges when i try to install the driver im running win7 64 bit
#47 |
Same here. It's telling me I need to log in as administrator, which is highly annoying because I ALREADY AM logged in as administrator. Grrr.
Lloyd Robinson Outrage 550, Protos 500, Exi 450 Pro, Blade 400 |
#48 |
Try XP compatibility mode, can help in such cases, though i dont recall needing to do that for mine.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#49 |
It worked when I just installed the driver directly from here:
http://www.silabs.com/products/mcu/P...CPDrivers.aspx
#50 |
Here is a current update walkthrough for Windows 7 with pictures. It can be a pretty extensive process.
http://www.diysoup.com/do-it-yoursel...ybarless-unit/
Aviation Ordnance, U.S. Navy Trex 250 DFC Pro, NCPX, mCP X, mCP X BL, 130X www.diysoup.com |
#51 | |
#52 |
What are you guys updating to? There are no new updates.
Sent from my HTC One X using Tapatalk 2
Lynx Team Pilot GrandRC Field Rep BEASTX |
#53 | |
#54 |
It's not about updating to anything new. It is a general walkthrough on how to update.
#55 | |
Sent from my DROID3 using Tapatalk 2
"It's not the crash so much as the sudden stop" Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... |
