| NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001 |
I have 325 blades on my Rave and would like to go up to 350 blades.
Do I have to change anything or could I just put them on and go fl?. I have the Next -D (2221-6) motor on 3S. |
350's are more suited to a 4s setup. But to answer your question, the model itself will accept 350mm blades as it is stock. No mods are required.
Brian |
It will likely work, but the longer and heavier blades will load everything more. Which can heat things up some, and reduce flight times. Like I said, they are really more well suited to a 4s setup. But I do know guys running 350s on 3s machines.
Brian |
350s work perfect on the 3s with 6 motor and is my preferred setup.
E-Aurora x 2, Trex 700, Trex 550, Trex 450, Rave, Blade 300x, Blade 130x and bunch of little helis |
#6 |
