Old 12-01-2010, 11:00 AM   #1
eltavito
Default Mini Protos on 4S
Does anyone know if 4S lipos are feasible with the 2580kv stock motor and the smallest pinion they offer (14T). I would like to use 1750mah 4S packs with this bird.
Occy
eltavito is offline        Reply With Quote
Old 12-01-2010, 01:26 PM   #2
Mikej
http://www.youtube.com/user/TheMSHeli#p/u/1/N6OMr92mFtw
Mikej is offline        Reply With Quote
Old 12-01-2010, 03:30 PM   #3
ted_wears_a_hat
ReadyHeli's headspeed calc indicates between 3.6 and 4.4k on 4s and that video says 3.75k, not sure what flight times would be though.
On an unrelated note, is it me or is the Mini-P in the video running metal blade grips?
- EF Blade 400 - HS65mg/DS760/DS8910/440H/HW40/SAB325/3s/10t - Flight Log: 308 -
- MSH Protôs Carbon - HS-5245mg/DS760/DS650/SportBEC/MSH26-10/Jeti80/SAB425/6s/13t - Flight Log: 76 -
- BUILDING! - MSH Mini Protôs Carbon - HS65mg/Quark/DS8910/Scorpion/YGE/SAB325/3s/16t - Flight Log: 0 -
ted_wears_a_hat is offline        Reply With Quote
Old 12-01-2010, 03:59 PM   #4
HighFreq
Blade grips were metal because mold was not ready yet at the time. All videos from ircha are on plastic grips.
If running it on 4S with stock motor make sure you limit throttle curve to have reasonable headspeed, do not exceed 3500 headspeed. That is a nice feature of having a good esc with great partial load ability out of the box
Corrado
HighFreq is online now        Reply With Quote
Old 12-01-2010, 10:20 PM   #5
Rob Cherry
Corrado
How about 6S? I've got my 450 rex running 6S and I'm looking to shelf the frame and move all the electronics to a protos mini. The 1630kv scorpion, 14T pinion and a good ESC would just scrape by at around 3500-3600 rpms. Maybe a Kontronik KOBY 40A or something. Even a LITE ICE 50 would work, CC's like over pinion setups anyway as mrmel headspeed calculates 3600 as max set rpm using CC software. Thoughts?
E7 | E5S | E5
Team Synergy | Gens Ace | Scorpion Motors | Progressive RC | Anything Heli
Rob Cherry is online now        Reply With Quote
Old 12-02-2010, 02:57 PM   #6
whisperdancer
Why do you need the Kontronik or the Ice? The stock ESC is ready for 6S and can be pushed to currents the Mini Protos will never achieve.
MSH Prôtos CF FBL Stretch - Scorpion 880KV, YGE 60A, 3x s9650, BLS251, VBar 5.1
E-flite HABU 32
Ikarus EXTRemA 330S
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
Old 12-02-2010, 06:51 PM   #7
fusuno
will the canopy fit well with 4s?
I just got the mini protos will assemble and check.
fusuno
fusuno is offline        Reply With Quote
Old 12-15-2010, 08:32 PM   #8
Blades_Cuts
Scorpion 2221-2010 should good for 4S, with the low gear ratio on the mini Protos. More "turn" = more torq less amp draw. And the governor mode will like it.
For 6S, 2221 -2010 can be modified to "wye terminate" from stock "delta terminate". That should drop the kv, from 2010kv / 1.74 = 1155kv, 15T-16T. Again "wye terminate", equals torq
-1630 is already wye terminate of 2221-10.
Blades_Cuts is offline        Reply With Quote
Old 12-21-2010, 08:28 PM   #9
bwijk
I have a 2221-10 and want to go to 6s. I was flying this motor on 4s and i loved it, but 6S. must be much nicer
So is it easy to convert my 2221-10 to a 2221-1630 Blades_Cuts?
bwijk is offline        Reply With Quote
Old 12-21-2010, 10:06 PM   #10
Blades_Cuts
I wont say it's easy, but it's not complicated either. Time consuming, specially if it's your 1st time doing it. I suggest you read on this link, before attempting it, or decide if you really want to try. Scorpion used a very thin wire guage that you have to separate and regroup to convert from delta to wye termination. You have to test for continuity so you know what wire belongs to a group. That's the hard part.
I already did it twice. It's doable, but it requires patience the 1st time. The next one I'll be doing is a full rewind to get to the spec I want.....
Old 01-01-2011, 07:31 AM   #11
audio131
Default 6s
do the 6s 1300 -1500 mah packs fit on the mini with the canopy? how does it balance out? im thinking of buying this kit and still have an old z power motor left from a g5 and a align 60 amp esc
audio131 is offline        Reply With Quote
Old 01-13-2011, 01:24 PM   #12
michael88997
has anybody tried 4s yet? what pinion works best. i believe i want to go 4s from the start to prepare for the stretch kit
michael88997 is offline        Reply With Quote
Old 01-13-2011, 08:58 PM   #13
Edvard R
I fly mine on 4s on the stock pinion. The YGE is a fairly good ESC and seems to do well running 55% TC.
Edvard R is offline        Reply With Quote
Old 01-14-2011, 12:44 PM   #14
JustPlaneChris
Interesting. What size packs are you using? Any canopy fit issues?
-Chris
JustPlaneChris is offline        Reply With Quote
Old 01-15-2011, 06:06 AM   #15
Edvard R
2200 mAh - fits perfectly under the canopy.
Old 01-18-2011, 03:59 PM   #16
Zumpo
Default 14T brakes on high load
I cannot recommend the use of the 14T pinion on 4S. Mine broke during flight. The outside is very thin and contains a one way bearing. When you give a full pitch impulse pressure is released from the one way bearing to the pinion breaking it. A 14T pinion may be solid enough for beginners, but it is definetly not for hard 3D.
I now use the 15T pinion getting about 3700 rpm at 65%. Hopefully it lasts longer. The Hyperion 4S 2100mah 25C batteries I use are just a perfect match for the small protos.
Zumpo is offline        Reply With Quote
Old 01-18-2011, 04:41 PM   #17
JustPlaneChris
Holy Headspeed, Batman!
I flew mine yesterday at 3100 and thought it was crazy... I can't imagine 3700.
-Chris
Old 01-19-2011, 04:13 AM   #18
macem
... headspeed 3700 rpm? it is hard to believe...
... 3800 rpm is the calculated (!) maximum (incl common deduction of 20 percent system-efficiency...) you can get with the stock-motor and15-pinion on 4s....
(14,8v * 2580kv / 8 gearratio * 0,8 efficiency)
so - you have got no 65% in the tx-manual, or no stock-motor.... or there was something wrong with meausring the rpms....
macem
macem is offline        Reply With Quote
Old 01-19-2011, 04:18 AM   #19
Zumpo
See video description text for details. Headspeed is about 3750rpm. A very good choice, if you ask me
Old 01-19-2011, 05:30 AM   #20
macem
... i know the vid, but i distrust the video description also ...
... even lungi cannot neutralize physics... but i may be wrong if the hyperion/scorpion/protos-kombi works without losses of efficiency or/and lungi runs the stock-pinion...
the hyperion lipo is inspiring, indeed....
regards, macem
