Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 12-02-2010, 07:59 AM   #1
SandMan123
Default Finished Build...but with lingering question
So I've done with the build now...but with the linkage setting called for in the manual the swashplate rides too high on the shaft, and there is not enough positive pitch and too much negative. I know how to fix this, but my question is: are the linkage lenths way off?
Trex 450 SE V2/450 Pro/Gaui X5
SandMan123 is offline        Reply With Quote
Old 12-02-2010, 08:04 AM   #2
torana74
Sandman, my flybarred one ,using Futaba BLS451's was almost spot on, just required a few turns. My FBL one needed a few more.
The link recommendations are just starting points that will have to be adjusted to your servos. Slight differences in servos etc
Wishing all the best for a succesful maiden
PS. if using the stock ESC, program the PWM to 8Khz. Alot are finding the scorpion prefers this setting
Enjoy
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote
Old 12-02-2010, 09:51 AM   #3
joe1l
Enjoy
Where did you find linkage length recommendations for the servo to swash rods. I had to do them from scratch. Luckily the the 451's were pretty easy to work with.
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
ElektroRC.com field rep (YGE, MSH, LAHeli)
joe1l is offline        Reply With Quote
Old 12-02-2010, 10:22 AM   #4
SandMan123
I took them from the manual that came with the kit. Does anyone know how far from the bottom frame block the swash should sit? In other words, what is the middle point (in mm from the bottom)?
Old 12-02-2010, 10:34 AM   #5
terrabit
The guide pin on the swash, when level and at zero pitch, should sit in the middle of the anti-rotation bracket. Just measure it.
terrabit is offline        Reply With Quote
Old 12-02-2010, 10:44 AM   #6
joe1l
Do you have FES or STD version?? I couldnt find anything for it. I just made sure everything was level and parallel and used my digital angle gauge ontop of the blade grip to ensure it was level or close to zero degrees.
Old 12-02-2010, 12:45 PM   #7
caralmar
I played with the swash for a while and found that 16mm from the CNC block to the bottom of the swash gave me level bottom mixer arms. From there, I just made sure that the top links were long enough to level the top mixer arms. So try 16mm and see how that treats you!
Rush 700 * Trex 700N x 2 * Trex 600Pro * Gaui NX4 - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote
Old 12-02-2010, 08:31 PM   #8
SandMan123
Okay, 16 mm thanks. I have the fb version
Old 12-03-2010, 03:32 PM   #9
caralmar
I have the flybar as well. How did the 16mm measurement work out for you?
AMA #934662
