Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 12-04-2010, 12:15 PM   #1
McOrbit
Default Collective and elevator at odds -)
Getting through my first set up and have "one" issue remaining..
When the collective works correctly the elevator is reversed, and by re-reversing the servos the elevator works but the collective is backwards. Any suggestions? thanks...mark
McOrbit is offline        Reply With Quote
Old 12-05-2010, 08:01 PM   #2
j bomb
Only use the servo direction settings in the interface to set the collective direction. If the cyclic is backwards, then use the AIL/ELE reversing functions in the transmitter as necessary to correct them.
John Barta
Michigan Whirlybirds Heli Club
http://www.michiganwhirlybirds.com
j bomb is offline        Reply With Quote
Old 12-06-2010, 06:00 AM   #3
McOrbit
Thanks!! Reversing the elevator servo in the radio did the trick. Now its all making sense, the elevator servo is actually the "elevator swash mix"...mark
Old 12-06-2010, 09:38 PM   #4
helienv
ha i was having kind of the same issue just there was nothing i could do to solve no combination of reversing would do anything i spent hours trying to figure it out then i went into the setup menu and realized that the radio was still setup for 120digrees mixing, FAIL. alot of time for nothing. turned it off and everything was fine. now im not getting the traval everything works kind of
helienv is offline        Reply With Quote
Old 12-06-2010, 11:07 PM   #5
McOrbit
"now im not getting the traval everything works kind of".. I might be able to help there (had the same issue -).. turn down the flight control , 'FC' in G-view, as far as possible, (28 or there abouts.) Reset the end-points and turn up the swash mixes in g-view (if needed) and then mucho travel!
I think with the flight control enabled it's corrections will almost cancel the radio inputs if you haven't set the endpoints.....mark
Old 12-07-2010, 07:33 PM   #6
helienv
after doing some work i got it at first i was getting uneven +- then i realized that 50% colective had a little positive pitch then i got the blades back to zero, with that made it was perfect 11 digrees for everything then i moved the travals up in the transmitter and it was great 14 14 14. what i still dont understand is how when i was setting up cyclic on a AR6000 i was able to get insane pos neg pitch 16-7 pos and neg. then when i pluged it into the total im only able to get 11 at 100%, where did all of it go?
