Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 12-08-2010, 03:49 AM   #1
1nv3rt3d
Default *Fusion 50 Setup's*
I have to say now that I am going to buy this chopper soon as I can and can't wait. Just wondering if we can start a thread on setup list's only here. I'm trying to figure out what all to use. So far here is my setup except the motor and lipo's.
What would be the flight time's on 12s 3500mah vs. 10s 5000mah?-
Also what pinion gear should I run?
Mikado Mini-Vbar-
Futaba bls251-
Cyclic-JR 8717HV's-
Castle Creation's 80amp esc-
Radix 600mm FBL Main's-
Radix 95mm tail-
Scorpion Motor?
Thunder power Lipo's-
JR 11X-
Spectrum Sat x2-
Robotronic's BEC-
Please feel Free to list your upcoming setup, Thanks!
NORTH ALABAMA MULTI-GP
1nv3rt3d is offline        Reply With Quote
Old 12-08-2010, 05:26 AM   #2
raptorheli2
spartan FBL when avail-flybar until then.
outrage tail servo
JR8915 running 8v.
castle creations 80HV ICE
sab 620 blades
radix 95 tails
scorpion 4025-550
turnigy nano 3300mah 12s
futaba 14mz
1500mah rx lipo
cheers
raptorheli2 is offline        Reply With Quote
Old 12-08-2010, 03:42 PM   #3
BonewJunior
Lukas Riva is running the 4025-630 and 2350 HS 100% Flat curve in the castle ice 80HV
Can't wait to see the prototype in the Orlando helicopter Blowout and get more info about setups for this machine.
I think the 12S setup is the best for this machine, I hope I can get 5 to 6 minutes with 3300mAh.
I like the Sab 620, Lukas is swinging the same blades, I go to run the v-bar 5.0 but I want to see how works the SK-720 on Lukas Fusion 50 to.
here is a video of Lukas Riva setup.
BonewJunior is offline        Reply With Quote
Old 12-08-2010, 04:04 PM   #4
1nv3rt3d
Yeah I'v read up on most of this stuff, and I was trying to decide over 10-12s setup. I also want a pretty nice flight time, and I don't think with a 12s setup 3300mah at 2350rpm will take more than a 4minute flight at best.
10s 4500mah will be more like 5min depending on blade size and how you fly of coarse. I don't really do hardcore 3D so I'll probably lean toward's the 12s with 3300mah and 600mm blade's, with less headspeed.
Any other motor choice idea's? Also, the motor mount bracket that they are using on these kit's, will the fusion 50 come with one, or where can I buy one?
Old 12-29-2010, 03:00 AM   #5
Floriandu31
MicroBeast
cyclique : MKS BLS 950
Tail : MKS BLS 980
Castle ICE HV 120
Voltage regulator : Gryphon
Motor : No decided yet Scorpion
Batteries : Nanotech 3300mAh 25-50C 12S
Batteries receiver : Nanotech 2200mAh 25C
Blades: Edge FBL 623mm
Tail Blades : Edges 95mm
Floriandu31 is offline        Reply With Quote
Old 12-29-2010, 11:50 PM   #6
kovar
Going FBL
HeliCommand HC3-Xtreme
Jr 8717 for cyclic
Jr 8900 on the tail
CC 80 HV
CC bec
3000 Mah 6's (going 12's)
Scorpion 4025-630
Team EMPIRE/ GAUI USA / Cyclone blades/ Scorpion Power Systems / YS Engines / JR Radios / Opti Power
kovar is offline        Reply With Quote
Old 12-30-2010, 07:46 AM   #7
guyro
FBL
Scorpion 4035-560
CC 120HV
TORQ 9088/9188
Mini V-bar 5.0
2* 5S 4000mAh
EDGE 603 or SAB 600
NRG 2S 2500mAh TX battery
guyro is offline        Reply With Quote
Old 12-31-2010, 02:41 AM   #8
SkinnyMcGee
Mircobeast
3000 6s nano tech (12s)
scoripion 4035-500kv
esc- unknown at this time
bec- unknown at this time
Edge blades all around
ar7000
Trex 450 Pro-Radix Paddles-Edge tail blades- Radix Blades- ICE 50-12t- Hitec HS-65MG
Trex 250 SE-Scorpion HK-2206-3900-Castle 25A-Jr 3500g-GY520
Outrage Fusion 50 FBL-V-Bar 5.1
SkinnyMcGee is offline        Reply With Quote
Old 01-01-2011, 02:49 PM   #9
chrlsdim
Fusion 50 FBL
CC80HV
4025-550
CC Pro bec
Skookum SK720
TORQ 9180
TORQ 9188
Thunder Power 45C 3800 6S X2
Futaba T8FG
Trex 800 pro DFC
chrlsdim is offline        Reply With Quote
Old 01-01-2011, 06:53 PM   #10
AnTi Taco
Fusion 50 FBL
Beast X AR700 / Full size Vbar undecided
9080 cyclic
9188 tail
CC 80 HV
4025-550kv 14t
EDGE 623mm FBL
Volts 3300mah 6s 35c/Volts 3700 if they fit also
2s RX pack
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote
Old 01-01-2011, 07:23 PM   #11
BonewJunior
Fusion FBL (12S)
4025-550 14T
MKS Servos
CC ICE 80HV
Western Robotics Hercules Super BEC
V-bar Blue Line 5.0 Full Size (S-Bus)
Edge 623 FBL Blades and 95 for Tail
Voltz 3700mAh
Old 01-02-2011, 08:30 AM   #12
Tokaz
Do you guys think the compass 6hv motor will fit the fusion50?
http://www.rc711.com/shop/12s-motor-...th=166_147_180 Fredde
Tokaz is offline        Reply With Quote
Old 01-02-2011, 10:02 PM   #13
Bart101
Fusion 50 FB ( May change to FBL )
Scorpion 4025-550kV
CC ICE 80HV
12s 3300
AR7100
Spartan Quark/Outrage BL 9088
Outrage BL 9080's on cyclic
Edge blades
Outrage Fusion 50 FBL - Outrage Velocity 50 FBL - Outrage Velocity 90 FBL
Bart101 is offline        Reply With Quote
Old 01-03-2011, 07:25 AM   #14
im4711
I am planning the following
FBL system MicroBeast
Cyclic: Outrage BL 9080
Tail servo: possibly Outrage BL 9188 (if it becomes available) / alternative JR8900 with voltage regulator to provide proper voltage
Motor: xera 4025/3y-560 (pinion -> have to see what main gear is on it in order to decide)
Blades: will test the Zigsaw blades first (weigh less than 114 gram each) and change possibly to Edge FBL as an option.
Batteries -> will use the Hyperion 2950 mAh packs (2 in series) for 12S setup at the beginning(have those on the TRex 500) and might change to 3300 mAh packs (depends on flight time and experience)
Hopefully this one will work OK.
im4711 is offline        Reply With Quote
Old 01-03-2011, 12:04 PM   #15
Bart101
Do any of you guys know what tooth pinion Lucas is using with his 4025-630??
Old 01-03-2011, 04:52 PM   #16
1nv3rt3d
I want to say I heard 14t. 13 would be good as well on this setup
Old 01-07-2011, 06:37 AM   #17
Blueabyss
Default Blades
In HeliDirects blade recommendations , they do not list any edge blades. Anyone know why? Does it have anything to do with the root thickness?
Chris
Blueabyss is offline        Reply With Quote
Old 01-07-2011, 11:06 AM   #18
AnTi Taco
nope i use edge blades on my velocity and fusion has the same head
Old 02-11-2011, 02:06 PM   #19
dougb
Default Outrage Fusion 50 setups
I couldn't find a setups thread so I guess I'll start one. Please post your setup & AUW.
motor: Scorpion HK-4025-550
ESC: CC Phoenix Ice HV 80
cyclic servos: Futaba S9452
tail servo: Futaba S9254
gyro / FBL: uBeast
blades: CY Radix 600, RotorTech 610
tail blades: stock
misc: (Lipos / BEC / Rx)
2 - Turnigy Nano-tech 6s 3000mAh, not sure on BEC or Rx pack
Futaba R6008HS
AUW: ???
Thanks,
Doug B.
dougb is offline        Reply With Quote
Old 02-11-2011, 04:28 PM   #20
HugoCraft
motor: Scorpion HK-4025-550kv (if I ever find one or if they come off BO)
ESC: Castle Ice-HV 80a
cyclic servos: Align DS610
tail servo: Align DS650
gyro / FBL: micro-beast
blades: Align 600D's and Curtis Radix 600mm but I have Edge FBL 623mm on BO
tail blades: stock, align cf, curtis, or some KBDD's
misc: (2) 6s 3600mAH 30C packs, AR7000 powered by Hobbico LiFe 1100mAh pack
AUW: ????? dont know yet, I only have the head and frame built
NOTE: I will update this post once I finish it
HugoCraft is offline        Reply With Quote
