Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-19-2010, 08:08 PM   #1
Lompma
Default Trex550e vs. Trex500
Not much price diff between the 2 but batteries seem to be cheaper for 500. Leaning towards the 550e. Any opinions.
Lompma is offline        Reply With Quote
Old 12-19-2010, 08:12 PM   #2
Wolfpackin
Definately the 550E, it dwarfs the 500.
And you can get good 6S 5000mAh batteries from HobbyKing between $55-$75.
I use the Zippy Flightmax 25C ($55 +shp) and 30C ($65 +shp).
Crash costs might also be a concern but well worth it IMO, and I'm pretty cheap.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 12-19-2010, 08:40 PM   #3
AzHeliCrasher
The 550 and 700 are my favorite. I would choose the 550 over the 500.
*Trex 550E, Beast w/Kontronik
*Trex 500ESP FBL Beast
*Previous helis: Trex 700LE-E,Trex 600 ESP, Trex 550, Trex 500 ESP, Trex 500CF, Trex 450 Pro, Trex 250, Blade 180CFX
AzHeliCrasher is offline        Reply With Quote
Old 12-19-2010, 08:42 PM   #4
suomynon
I'm still sport flying (just started in July with a 450 then a 500 3G in Oct), but I'm hooked on the hobby and thinking about a 550 3G soon.
Is a full-sized soccer field enough space for a 550? (Trees on three sides...)
If I already have a 500, does a 550 sport fly enough better to make it worth adding to my fleet? How about 3D?
Compass Atom 7HV. Align T-Rex 550.
suomynon is offline        Reply With Quote
Old 12-19-2010, 10:04 PM   #5
Blades345
Go with the 550 over the 500,, better power and much bigger. The 550 will fly way better than the 500 will
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!!
No helis right now! Maybe I'll be back in another year!
Blades345 is offline        Reply With Quote
Old 12-19-2010, 11:24 PM   #6
jauguston
I have a 450 and a 500 and am now assembling a 550e. The 550 is definitely bigger than the 500 but the 500 is one sweet flying heli.
Jim
jauguston is offline        Reply With Quote
Old 12-19-2010, 11:34 PM   #7
FlyNHelis
If money is not an object. Between the 500 or 550. I would have to go with the 550 kit. For the simple fact that, you can buy 500 size batteries and use it for the 550. Now the 550 kit can use upto 5000mah lipos as well. Meaning more flight times, also not to mention the stability as well. Just my thought.
FlyNHelis is offline        Reply With Quote
Old 12-19-2010, 11:42 PM   #8
aralan
The 550 is much closer in size to the 600, it's quite a bit bigger than the 500.
500 = 425mm blades
550 = 520mm or 550mm blades
600 = 600mm blades
A Main Hobbies
aralan is offline        Reply With Quote
Old 12-20-2010, 09:31 AM   #9
kidphc
Only an 1-2" difference in length between a 550 and 600.
MSR,McpX 250SE, 450SE (pro now) V2 3g,12s Trex 550e
Sold: Trex 500 3g, 600n
kidphc is offline        Reply With Quote
Old 12-20-2010, 09:40 AM   #10
rctazz
The 600 is 4.7 inches longer than the 550E
The 550 is 8 inches longer than the 500. Side by side and in the air, the difference is huge between the 500 and the 550.
Jim
Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700
Keep it off the Ground....but just barely
rctazz is offline        Reply With Quote
Old 12-20-2010, 10:43 AM   #11
jauguston
If you plan on using 500 batteries in a 550 you better plan on using two. It will never balance with one 500 battery.
Jim
Old 12-20-2010, 12:17 PM   #12
kidphc
Sorry, you are correct. I was thinking about a 550e and stretched 550e.
Picture from RC groups comparing the sizes.
Old 12-21-2010, 04:59 AM   #13
darinr80
550E. Done.
Align Trex 550E BeastX FBL - RCE-BL70G ESC, 600M Motor, DS610, DS620
Align Trex 450 Pro AR7200BX FBL - Castle ICE Lite 50 ESC, KDE motor (3500KV), DS410M (Metal Gear), DS520
Eflite Blade mCP X - C05M 11,000kV brushless motor & XP-7A ESC.
darinr80 is offline        Reply With Quote
Old 12-21-2010, 08:25 AM   #14
ziper_it
Great choice!
F
ziper_it is offline        Reply With Quote
