Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 01-02-2011, 02:43 AM   #1
SkinnyMcGee
Default Fusion Pre ordered need help
hello everyone i ordered my fusion fbl yesterday, will this set up work
CC80HV - $160.00
CC BEC PRO- $40.00
2 6s 3000Mah - $100.00
Microbeast or beastx- $225.00
AR7000- $100.00
Scorpion 4025-550kv - $150.00
Savox 1257TG- 200.00 (for 3)
JR DS8900G- 140.00
Fusion 50 fbl -390.00
Trex 450 Pro-Radix Paddles-Edge tail blades- Radix Blades- ICE 50-12t- Hitec HS-65MG
Trex 250 SE-Scorpion HK-2206-3900-Castle 25A-Jr 3500g-GY520
Outrage Fusion 50 FBL-V-Bar 5.1
SkinnyMcGee is offline        Reply With Quote
Old 01-02-2011, 06:25 AM   #2
kovar
Can you run satellites on the beast x?? I have no clue about the savox servos, the rest of it looks good..
Team EMPIRE/ GAUI USA / Cyclone blades/ Scorpion Power Systems / YS Engines / JR Radios / Opti Power
kovar is offline        Reply With Quote
Old 01-02-2011, 09:30 AM   #3
raptorheli2
microbeast and beastx is the same thing is it not?
yes you can use 1 sat rx on the beastx which means it is not suitable to use as an rx in models over 500 size.
cheers
raptorheli2 is offline        Reply With Quote
Old 01-02-2011, 04:44 PM   #4
SkinnyMcGee
yeah beastx and microbeast are the same thing
Old 01-02-2011, 05:00 PM   #5
AnTi Taco
don't forget to use the 10% off it expires today at least order the FBL kit today.... I WOULDN'T USE THAT BEC get a western robotics super BEC or you can run a 2s pack the savox/align at supposed to run 6v but can run 2s pack with no problems.... or for 25 bucks more with the discount you can get the outrage servos fvor $224.00 and run 2s lipo pack and that saves you money from not buying a bec
i say get the outrage servos it will save you $$$
http://www.helidirect.com/western-ro...ak-p-11292.hdx
http://www.helidirect.com/outrage-90...bo-p-21240.hdx
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote
Old 01-03-2011, 06:07 AM   #6
DRM Black7
You can not run a beastx on 2s lipo with out bye passing the beastx power bus or just run it all at 6v regulated through the Beast.
Nearly lost my 550 big time running 2s
Gaui X7 Formula
Trex 450L Dominator
Oxy 3 Lynx pilot. 2nd place Sports class, Helifest 2015
DRM Black7 is offline        Reply With Quote
Old 01-03-2011, 07:02 AM   #7
im4711
You are wrong -> you can run MicroBeast on a 2S setup. Your issue is the tail servo that needs to be regulated down. BEsides that just read the specs on MicroBeast documentation and you will see:
"Operating voltage: 3,5V...8,5 V DC (Lipo 2s possible)"
Again issue is the tail servo that most often is not rated for high voltage and has to be regulated down. If you want to run that on HV too -> check about availability on Outrage Tail servo's.
im4711 is offline        Reply With Quote
Old 01-03-2011, 07:21 AM   #8
DRM Black7
Even the Beastx developers do NOT recommend high voltage set ups through the unit. There's loads on this on helifreak.
And no I was useing a spektrum duel regulator on the Tail.
I think beastx have dropped a ball on this one and should amend the specs
Gaui X7 Formula
Trex 450L Dominator
Old 01-03-2011, 07:25 AM   #9
DRM Black7
If you value your heli please carry out a bit of research on here and the Beastx forum before running 2s unregulated on cyclics
Gaui X7 Formula
Trex 450L Dominator
Old 01-03-2011, 04:10 PM   #10
AnTi Taco
QUOTE from the beast website
Old 01-05-2011, 09:53 PM   #11
labmaster
Sorry, thats bullsh..., noone of the offical beastx guys ever told such.
We only told, that you have to make sure that your servos are able to keep up with the very high demand that is involed if running on a control system (a ggod FBL system is like a high performance Tail gyro) together with "High Voltage".
We've already seen servos dieing in such configurations.
best regards,
Walter
labmaster is offline        Reply With Quote
Old 01-06-2011, 01:58 AM   #12
DRM Black7
Think you need to clarify that with your uk distributor I'm pretty pissed off now, been mugged of, told to change my setup when all along it was a faulty Beastx. And to make matters worst they have had the unit 4 weeks, this was an early Xmas present from my wife so all in all a Total balls up!!! the thing is I've been running flybared now for the past 7 weeks not sure if I can be bothered with all this bollocks
Gaui X7 Formula
Trex 450L Dominator
Old 01-06-2011, 06:05 AM   #13
kazager
LOL, Love your vocabulary. I almost need an English to American dictionary...that's great, keep it up!
Sorry for your troubles
kazager is offline        Reply With Quote
Old 01-06-2011, 10:42 AM   #14
DRM Black7
Lol cheers back on topic, sorry guys I hate giving out wrong info, just going on what I was told
Gaui X7 Formula
Trex 450L Dominator
