Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Mars/Poseidon
Mars/Poseidon Mars and Poseidon Helicopters
Old 01-26-2011, 11:50 PM   #21
praetorious
Great news! Congrats!
Kiss the Sky
Gazaur Mars 480 XL, Gazaur Poseidon 480, Blade CPP+
DX7
praetorious is offline        Reply With Quote
Old 01-27-2011, 08:06 AM   #22
benwhite22
Hey, that's great. Thanks for letting us know that you found success.
T-Rex 450 S, T-Rex 500, Pantera 50, Turbulence D3 (one can dream)
benwhite22 is offline        Reply With Quote
Old 03-03-2011, 07:35 PM   #23
<3My480Pro
I'm having the same problem as arquitron. Esc kept beeping after connecting the bat. Maybe shock damage?
<3My480Pro is offline        Reply With Quote
Old 03-03-2011, 08:21 PM   #24
praetorious
The spark that you see will at most cause pitting of the connectors in the pain power harness. Can you check your motor for continuity across all 3 phases, or with another working ESC. That will tell you if it is a problem with the motor or ESC. Provided the motor checks out, you might have to fiddle around with ESC settings or Tx settings and see what happens. Which ESC are you using?
Kiss the Sky
DX7
Old 03-03-2011, 10:15 PM   #25
arquitron
In my case the problem was a faulty connector on the motor's black wire.
arquitron is offline        Reply With Quote
Old 03-04-2011, 04:05 PM   #26
<3My480Pro
I'm using the gazaur v1 55a esc. had the motor checked out and it's running fine. swap the esc to my rex and same problem. i inspected all connections and wires and everything looks like the first day out of package.
Old 03-04-2011, 04:29 PM   #27
praetorious
Well it must be a transmitter settings thing. Is your throttle channel reversed? Is there any throttle trim? try resetting your endpoints?
I've never used this ESC btw.
Kiss the Sky
DX7
Old 03-04-2011, 04:35 PM   #28
<3My480Pro
all settings still the same from the day of the crash. while battery connected i have full control of servos except the motor.
Old 03-08-2011, 12:24 PM   #29
arquitron
Did you figure out your ESC issue?
Old 03-08-2011, 10:39 PM   #30
kavic5150
Talking
Happy ending! Lol.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is online now        Reply With Quote
Old 03-08-2011, 11:06 PM   #31
arquitron
3My480Pro,
I think I know what is happening with your ESC. You may need to program max and min throttle limits on your ESC first before doing any programing for your motor.
Uninstall your motor pinion or move your motor so it does not mesh with your main gear. Move your throttle stick to max, then turn on your TX , connnect the batery to your ESC, you will hear a beep and then the led on your ESC will blink repeatedly, wait 6 to 8 secs and move the stick to min throttle, your will hear one more beep and your throttle limits (max and min) are set in your ESC.
Let us know how it went.
Old 03-09-2011, 12:47 AM   #32
praetorious
Go arquitron!
Kiss the Sky
DX7
Old 03-09-2011, 07:12 AM   #33
arquitron
Originally Posted by praetorious View Post
+1
Go arquitron!
It's just the beauty of HF... get help and help others in your path!
Old 03-09-2011, 01:32 PM   #34
benwhite22
Ahhhhh
Old 03-11-2011, 04:26 PM   #35
<3My480Pro
I've tried everything and still no luck. even swap out all wires and same thing. ordered a new esc from dave and the bird is ready for flight.
Old 03-11-2011, 05:43 PM   #36
arquitron
Good to hear you solved your issue.
Old 03-11-2011, 09:46 PM   #37
praetorious
Cool, tell us how your flights go. What charger/parallel board is that? Also, I wouldn't strap the power supply and charger together, because of possible hear issues.
Man, I'm jealous of all your packs. I've got to buy some new ones.
Kiss the Sky
DX7
Old 03-12-2011, 02:03 AM   #38
<3My480Pro
thanks arquitron. flight was great today praetorious. a bit windy where i was at but the bird held it's ground. i made a few mods to both the charger and the PS so there's barely any heat issue. swap out the cheap clay heating material with artic silver and made a few extra vents.
Old 03-12-2011, 03:01 PM   #39
<3My480Pro
