Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > 330X
330X Discussion and support of the Gaui Hurricane 330X QuadCopter
Old 01-09-2011, 12:26 PM   #1
Coolpowered
Default 330x strange wobble
I have a 330x with scorpion motors and 10 amp speed controls, my problem is when I'm flying fast foward and go into a fast forward banked turn the 330 gets a wobble in it like a glitch for a second, and was wondering if anybody else has this on theirs, and what they did to correct it.
Coolpowered is offline        Reply With Quote
Old 01-09-2011, 01:24 PM   #2
RotaryBliss
have you tried lowering the gain some? It still may be a bit high for when its loaded.Even though it holds on hover well.
Team Tail-in / Helifreak Elite Bacon Awareness Committee
RotaryBliss is offline        Reply With Quote
Old 01-11-2011, 12:58 AM   #3
helidaho
This may be a stupid question but do you have it in cruise or hover mode? In hover mode I believe it is more aggressive in trying to correct itself.
If you are in cruise, which works best anyway, then you may need to reduce your gain a bit.
Paul
Blade MCX S300 / Blade mSR / Blade 120SR / Blade 400
GAUI Quad 330x
helidaho is offline        Reply With Quote
Old 01-11-2011, 06:03 PM   #4
Coolpowered
I tried adjusting the gains in both cruise and hover mode with no effect. My buddy just got a 330x and his does the same thing, and even has a little wobble in fast forward once in a while like a fast glitch. We are both flying using 2 motors for the front end of the 330, I might adjust the gyro for just one motor being the front end to see if it is any better.
