Old 01-09-2011, 12:41 PM   #1
bj660raptor
Default bec choices.
Ill be running a align 650 on the tail,3517 cyclics,fullsize vbar,and a 30c 1000 3s rx pack...which bec whould be right for this setup,,,currently running a western robotics highcurrent,5a,,,,will this work or should I get the ccbec pro,or what have you,tia
Trex 700DFCHV,helijive,vbar 5.2 pro
Goblin 500 bls 153,bls 251,jive 100,pyro 600-12 20t pulley,mini v 5.3 pro
Rockin TP 65c and 70c and Futaba 8FGS.
Pilot Brandon J.
bj660raptor is online now        Reply With Quote
Old 01-09-2011, 01:10 PM   #2
dannylightning
most of us don't use a bec on the 500
if i were to use one it would be the sport bec.
GAUI X5. = pure awesomeness
youtube.com/dannylightning
facebook.com/dannylightning1313
dannylightning is online now        Reply With Quote
Old 01-09-2011, 01:23 PM   #3
GunnyGlow
You're going to be running a separate RX pack?
You can use almost any BEC if that's the case and not worry too much. Although, I use a 2S lipo for my RX packs b/c it's easier for a BEC to step down a few volts rather than double the voltage from a 3S pack. I prefer the CC BEC, the regular ol blue one, if using a separate RX pack. I would be somewhat apprehensive of using one with anything larger than a 3S....but....
I guess with your power hungry setup, a BEC on a separate RX pack isn't a bad idea.
GunnyGlow is offline        Reply With Quote
