Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 01-11-2011, 09:27 PM   #1
silas3d
Default KDE Direct TREX 700e Battery Tray Issues
I just picked up a couple KDE Direct Battery Trays and am really having trouble getting them to slide smoothly along the battery tray rails. I bought three, one is smooth, the other two are extremely tight. The stock plastic trays work just fine.
Anybody else having this issue?
Lean not on your own understanding.
TDR 2011 | SAB Goblin 700 | SAB Goblin 500 | Coast Guard UH-60
silas3d is offline        Reply With Quote
Old 01-12-2011, 12:04 AM   #2
Fredrik R
Have 4 of them and they are fine...
Have you measured those that are tight if they are thicker?
Fredrik
Team Scorpion
Fredrik R is offline        Reply With Quote
Old 01-12-2011, 08:38 AM   #3
silas3d
Yes. According to my digital calipers they are about 5-10 mils thicker than the stock trays; which isn't that much thicker.
I was playing around with them some more last night and after putting a small amount of grease on the tray edges they seemed much easier to install.
They are still very tight, but I got an email back from Patrick at KDE who said they designed them to be tighter so the batteries wouldn't rock back and forth. Guess I'll just get used to it...
Old 01-12-2011, 07:34 PM   #4
jack726
Well they may be intentionally tighter, but I had to put one through my mill to get it loose enough to install. I could not push it in with my two beefy hands. The Align, plastic one fit perfectly.
While on the subject: I had to machine the motor mount to allow the motor to slide to adjust it.
Oh Yeah: I remember now: on my fourth flight, my KDE main gear melted to a glob. I was able to land my expensive scale model 10 seconds before the whole thing locked solid.
You know: I don't think I am that impressed with KDE.
jack726 is offline        Reply With Quote
Old 01-13-2011, 08:43 PM   #5
nuclearchip
Mine just arrived.... I can't use it unless I somehow mill it down. The width dimension is slightly too big. I have 4 plastic trays that slide right in.
SAB Goblin, Scorpion 4525 520 LE, Jive HV120, Beastx. Fusion 50 Flybarless Beastx CCHV120 Quantum 4035 530 AR8000 with JR 9503. Team HeliDirect
nuclearchip is offline        Reply With Quote
Old 01-13-2011, 10:33 PM   #6
Wizza
That is very disappointing, and especially considering the cost of the KDE trays. This thread settled my mind to try the carbon trays from CHP....
Regards, Mark R
TRex 700E - V-Bar v5.3 and BLS251, DS8915's, HJive120, JR DSMX Sats, JR DSX12
TRex 600ESP - V-Bar v5.3 and DS8900G, DS8717's, HJive 120, JR DSMX Sats, JR DSX12
TRex 500CF - Mini-V v5.3 and DS3500G, JR DS3405's, JR DSMX Sats, JR DSX12
Wizza is online now        Reply With Quote
Old 01-14-2011, 12:32 AM   #7
silas3d
Yeah I ended up filing mine down a little. It didn't take long and now they do slide in and out. It's still pretty snug though. At first I thought I had "pinched" the frame too tightly at that middle support, but even after loosening that and the RX mount screws they were still tight.
Don't have to worry about them sliding out accidentally!
Old 01-14-2011, 06:45 AM   #8
~Cliffman~
I was having the same problem with my KDE's until I realize the battery was being pinched between the tray and the rail. Installed some velcro which created a space/gap between the tray and the battery and now it slides realy nice.
~Cliffman~ is offline        Reply With Quote
Old 01-15-2011, 09:38 AM   #9
nuclearchip
I don't have a battery mounted on it. It is bare, and too wide. Not by much,, but it won't slide in passed the first 2 inches or so.
Old 01-28-2012, 12:20 PM   #10
Lorbeer
Has anyone tried the carbon trays from CHP? Are they better?
Align T-Rex 450 Pro
Align T-Rex 700E
Align T-Rex 700N
Mikado Logo 500SE
Lorbeer is offline        Reply With Quote
Old 01-28-2012, 07:56 PM   #11
spikestabber
Are these the V2 trays you guys are having issues with?
I have 3 sets of V1 trays and they slide in flawless.
Edit: That's what SHE said.
T-REX 450Pro DFC, SK-720, CC Lite 50, TM1000, KDE 450XF, MKS DS95's, Futaba BLS-257, KDE, DX8
T-REX 700Ev3 DFC, SK-720, CC 160HV, TM1000, KDE 700XF, Outrage BL9180's/BL9188, KDE, DX8
spikestabber is offline        Reply With Quote
Old 01-28-2012, 10:53 PM   #12
Mystic3D
I have 4 of the KDE trays and they are very tight. I just greased the rails and it made a big difference.
Trex 700E, YGE 120HV,, Xera 4035/,8917/ VBar
Mystic3D is offline        Reply With Quote
Old 01-28-2012, 11:13 PM   #13
ChrisH
Why not use the Align V2 trays??
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is offline        Reply With Quote
Old 01-29-2012, 01:20 PM   #14
DoctorJ
Exactly, they are freaking awesome, including the snap in feature...
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - CC 50
Blade 130x - HP08 - CC ( many others )
DoctorJ is online now        Reply With Quote
Old 02-07-2012, 06:24 PM   #15
robertsm
Exactly what Im ordering
Trex 700E - Vbar, 700MX, 8917HV, BLS251, ICE 80HV, Fromeco Kiwi, edge 693mm
Trex 600 LE nitro - O.S. 70 motor, Align 90 muffler
Trex 550e - Mini vbar, edge 523mm
Trex 450 sport
robertsm is offline        Reply With Quote
Old 02-07-2012, 06:33 PM   #16
Wizza
I ended up order the new Align V2 nose with the push-button locking clip and the new V2 Align metal battery trays. They are absolutely awesome, and they just work first time... I just installed a KDE performance tail unit last week on my 700, and had to resize a spacer and adjust the loose fitting mount before it all worked smoothly. A simple upgrade took two nights of dicking around and re-engineering to get it to work smooth and eleminate the play in the KDE factory parts....... HHmmmmmm.. The concepts and ideas are awesome, however the KDE manufacturing and quality control seems to leave a bit to be desired....
Regards, Mark R
Old 02-07-2012, 08:08 PM   #17
NRPY
+1 for the Align V2 trays. They fit perfectly.
NRPY is offline        Reply With Quote
Old 02-07-2012, 08:28 PM   #18
Lorbeer
Thanks to this thread I did indeed get the Align trays. Thanks guys!
Align T-Rex 450 Pro
Align T-Rex 700E
Align T-Rex 700N
Mikado Logo 500SE
Old 02-08-2012, 07:42 AM   #19
Dino Spadaccini
Mystic3D your best bet would to call KDE and see how he supports this problem
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote
Old 02-08-2012, 08:56 AM   #20
KDE Direct
This thread started over a year ago, and I'm not aware of any issues with the KDE Direct Battery Tray Upgrade V2s. If you do have an issue, same as any product we offer, please feel free to e-mail me at patrick@kdedirect.com and we'll get you taken care of. The trays are purposefully machined to be an accurate fit to the rails, so there should be not issues with installation for you and the V2 version includes the necessary features for proper operation of the ALIGN Receiver Mount Latch design.
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote
