Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 200
Hurricane 200 Discussion and support of the Gaui Hurricane 200
Old 01-12-2011, 10:15 PM   #1
OCFly
Default Equpment recommendations..
Hello,
First of all, I just want to say thanks to all of that contributed in this Gaui forum. I've learned so much lurking the halls since I'm a total NOOB. Really a beginner when I comes to flying as I find it more enjoyable building these small helis.
Question is what would you recommend in regards to:
1. Cyclic servos..just purchased Hitec HS5045..will these do?
2. Tail Servo
3. Gryo
Already have stock motor and ESC with my kit.
Any feedback greatly appreciated.
OCFly is offline        Reply With Quote
Old 01-13-2011, 03:31 PM   #2
nexgen
The stuff in my sign works great. The 290g is a great tail servo.
Rooted MT3G + Cyanogen Mod 6.1 + Tapatalk = WIN
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote
Old 01-13-2011, 05:42 PM   #3
heathy
Maybe cheaper for you as a beginner to use the hitec 45's instead. There not digital as the one's you've mentioned and cheaper.
You will crash lots, so every penny's gona help
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote
Old 01-13-2011, 07:47 PM   #4
Ampdraw
My No 1 suggestion....don't skimp on the tail.
Minimum I would fit would be the SJGD mini one ($70 Turnigy Mems rebrand at Hobbyking). But you are probably better off to shell out the cash for either a Quark or a GY520.
A new in pack Align GP750 may be a good less expensive option as well.
Tail servo...JR290, Hyp DS11GCB or Inolab 201HB are my rec. Personally I use the 290 but if I were buying today would probab go the Ds11.
Amp
Ampdraw is offline        Reply With Quote
Old 01-13-2011, 09:31 PM   #5
clytle374
Amp
Just wondering why the DS11 over the DS09gmd?
clytle374 is offline        Reply With Quote
Old 01-13-2011, 09:47 PM   #6
Ampdraw
When these servos were first released many found (on *******) that the 11 was better on the tail than the 09 even though the spec is the same. I believe the 11 has an 11mm dia motor and the 09 has a 9mm. Seems the 11 was more able to provide the speed at a given torque.
On another note I hope MKS venture into smaller servos.
Check out this: http://www.mks-servo.com.tw/goods.php?goods_id=ds95i
Amp
Old 01-15-2011, 09:42 AM   #7
fusionsx00
I thought hitech hs 45 were digital?
I have to double check mine but I know there hitech digital feather servos
I have a quark and jr 290 g
I would not recomend going cheap on tail,
fusionsx00 is offline        Reply With Quote
Old 01-15-2011, 04:47 PM   #8
clytle374
There is a digital version of the hs45, but the hs45s aren't digital. I looked at the digital versions but they are the same price as the Hyperion DS09s which has much better specs.
A agree with everyone that fighting cheap stuff on the tail isn't worth it. Been there, still doing that.
Old 01-15-2011, 08:11 PM   #9
OCFly
Thank you all for your feedback. I am still doing research on your suggested products. I'll make sure I post some pics when my project is complete.
Old 01-15-2011, 08:53 PM   #10
fusionsx00
I found mine for 17 a piece, online brand new
digital servos
im running a dx8 and a ar7600 11ms frame rate.
I tried to go cheap as a newbie, bad mistake, I spent more time fixing then flying
now with good parts I fly more than troubleshoot, fix, repair, replace cheap parts that didn't last, didn't work well
Old 01-15-2011, 09:33 PM   #11
clytle374
digital servos
Looking at your signature line for digitals, you got the Hyperions for $17? Where? I need some.
Old 02-05-2011, 11:11 PM   #12
BHChieftain
What's the difference between the hyperion SCD, AMD and GMD digital servos? Which would be best for the gaui 200?
Chief
BHChieftain is offline        Reply With Quote
Old 02-06-2011, 02:43 AM   #13
clytle374
The G is fast, like for a gyro.
The S seems to be for 'normal' where the A was for abusive situations I read somewhere I can't quote.
The 2nd letter C stands plastic gears and M for metal.
I was installing my DS09s tonight and the plastic spacers for mounting servos solid sprung the ears on the cases pretty bad. Worrying about if it would break later I decided to check and see how much a case cost. Then I found out that Hyperion doesn't sell replacement cases. Never expected that, so I didn't look. I wish I hadn't bought them now.
Old 02-06-2011, 11:00 AM   #14
BHChieftain
Thanks for the secret decoder ring...
Chief
Old 02-06-2011, 11:32 PM   #15
BHChieftain
Default Heading gyro for 200 V2 Flybar version
Hi,
Trying to sort out tail gyro choices. What do you think about the GY520 vs. GY401?
If Quark is preferred, which model?
Thanks,
Chief
Old 02-07-2011, 12:01 AM   #16
clytle374
Hopefully someone else will jump in and confirm that I'm correct. The Gy520 is the better of the 2 futaba gyros.
I don't know that the Quark is better. There is a setting on the GY520 that people say helps on the small helies. I don't know of diffrent models of Quarks, but they do come in different cases. I chose the Quark because the GY520's manual says you can't use it with a 72mhz system.
Old 02-07-2011, 12:34 AM   #17
BHChieftain
Thanks. Also, I just figured out that "Quark" *is* the model name...
Chief
Old 02-07-2011, 05:17 PM   #18
nexgen
Chief
here are what the letters mean:
A- Normal torque and speed
F- High Torque/Speed blend, Mod Current
G- Ultra high speed
H- Very high speed / low current
S-High speed/med torque/low current
T- high torque / less speed
U- ultra high torque / lpw speed
C- carbon ploy gears
M- metal gears (primarily)
P- plain bearings
B- top ball bearing
D- twin ball bearing
xT- coreless motor, extreme torque (compared to std type at similar speed)
xS- coreless motor, extreme speed (compared to std type at similar torque)
using this my DS09-SCD's are:
9 gram servo
The DS09AMD is:
9 gram servo
and the DS09GMD is
9 gram servo
G- Ultra high speed
you can see why I chose the SCD over the AMD. I wanted speed on the cyclic, there is enough torque for my application, and I wasn't concerned with metal gears here.
for my big bird,
DS 20 FMD's:
Old 02-07-2011, 10:30 PM   #19
BHChieftain
Awesome.
Got another question on the Quark config-- I noticed that there is a metal version and a plastic version, and the FAQ at the Quark site says that in some cases the metal version, while 2g heavier, may be heavy enough to be used without the extra metal mounting plate to isolate vibration.
So with the JR servo, are you using the metal or plastic Quark? With or without the metal mounting plate?
Thanks,
Chief
Old 02-07-2011, 11:44 PM   #20
nexgen
Metal Quark on the tongue up front using the black foam quark sized pad only
