Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 01-14-2011, 01:17 PM   #1
505b400
Default what size motor would give me longer run times?
i am looking for more run time out of my 550, i have the bigger of the gaui motors( i dont know what size i want to say 1400 or 1600, if that makes sense). i was thinking of trying to find the smaller one and try to run that one instead.
505b400 is offline        Reply With Quote
Old 01-14-2011, 01:23 PM   #2
Mikej
It's not just down to size, for long run times efficiency is important and to give you as much flexibility as possible on teh gearing you want a motor with a KV around about 900 - 1000kV. Ideal choices are the Z-Power (tonic-X) Z20A 980kV or the Scorpion 3026 1000kV - these are both efficient (the Z20A is very efficient) and will give you lots of alternatives on gearing - if you go for a 1400kV motor you will need to go with a 60T main gear and a 13T pinion - I don't think that you will get a 1600kV motor to work with a decent set up
Mikej is online now        Reply With Quote
Old 01-14-2011, 05:02 PM   #3
masjo
Motor, gear train and flight packs all play apart in flight times and efficiency. And again as mentioned many times.....more packs = more flight time.
What componants you install and your flying skills is what make a good flying heli.
masjo is offline        Reply With Quote
