Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 01-16-2011, 04:43 PM   #1
im4711
Default Motor shaft for Fusion 50 - question for outrage?
I start getting concerned I might have the wrong motor shaft. I have a regular length 6 mm shaft. I know since a few days that the 5 mm pinion support and pinions will be shipped with the kit.
What I cannot find out is if a long shaft or regular shaft is needed. Looked at the videos and pictures. None shows the information. Also looked at the specs and that does not tell. I am just concerned that the regular shaft length is not long enough.
Any decent answer maybe even from Outrage itself would be appreciated.
I send a few requests on outragerc website a few weeks ago but never received any answer. Maybe it better works on the forum.
im4711 is online now        Reply With Quote
Old 01-17-2011, 04:04 PM   #2
Andrew@OutrageRC
Hi
To use the pinion support, you require at least 30mm of motor shaft beyond the motor case.
I am not sure which make of motor you plan to use but, for example, the standard shaft on a Scorpion 4025 series motor fits this criteria.
http://www.scorpionsystem.com/files/i1,509_full_dimension.pdf
Hope this helps
Andrew
Outrage RC When you Simply Need the Best
Andrew@OutrageRC is offline        Reply With Quote
Old 01-18-2011, 04:47 AM   #3
im4711
thanks - I have to check this. I plan to use the Xera 4025-560 3Y. I will check the length.
Old 01-18-2011, 05:29 AM   #4
im4711
Looks like I do not have the 30 mm shaft length. Even the Scorpion HK-4025 series seems to have some models with about 25 mm shaft legth (checked several web sites where I see overall shaft length a bit over 70 mm and motor itself a bit over 50 mm).
That seems to be odd since Scorpions website says different.
So if I have a shorter shaft does that only mean I cannot use the pinion support and is that even doable?
