Old 01-22-2011, 11:10 AM   #1
banditpowdercoat
Default What's ur Expo%??
I'm running 40% expo, well in the SIM anyways. I'm wondering what do people run? I kinda feel like higher is cheating, but can't get a smooth hover with anything lower.
banditpowdercoat is offline        Reply With Quote
Old 01-22-2011, 01:27 PM   #2
nice,whatdoesitdo?
im running 30 on everything at mo, but plan on dropping to about 15 soon, as i want more response. if you go to high on it, youll end up over correcting. try 30 out
nice,whatdoesitdo? is offline        Reply With Quote
Old 01-22-2011, 01:41 PM   #3
seanrock
I started at 20 and I'm down to 10, it's just a learning curve.
seanrock is offline        Reply With Quote
Old 01-22-2011, 03:17 PM   #4
Helisun
I'm still at 30. Sometime I go 20 depending on wind condition.
Helisun is offline        Reply With Quote
Old 01-22-2011, 03:21 PM   #5
Jeff_Barrett
I don't use expo.... I feel too disconnected with it.
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 01-22-2011, 05:06 PM   #6
CACN
I have -10% on all Aileron, Elev and Rudd.
Henseleit TDR, Helijive 120HV, HC-3SX, HKIII 4035 560KV
Minicopter Diabolo, Helijive 120HV, AR7200BX, Xera 4530 500KV
Align Trex 550, Beastx, 600MX
Hirobo SRB Quark
CACN is offline        Reply With Quote
Old 01-22-2011, 05:13 PM   #7
CoolKD
Running 25% cyclic and 13% on tail(GY520)
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro. KDE FBL Head & BatTray,MKS DS95,FutabaBLS257,BeastX, ICE50, CC BEC, Scorpion6
Align Trex700LE N. LYNX Clush/Liner, Quark,Hatori SB20FH-2,O.S91HZ
CoolKD is offline        Reply With Quote
Old 01-22-2011, 06:33 PM   #8
newflyguy1
Can't you just lower your swash % for elevator &/or aileron? That will smooth out your stick inputs & slow each one down a bit but you won't loose stick range. I usually set my elevator swash % about 5-10% higher than my aileron when I plan on doing forward & back flips. That way the roll is less likely to tip the heli & I can flip pretty quickly. Or the other way around for rolling 360's.
I do have a little expo on my rudder though on a couple models in my 7c Tx, 15% set to a switch for when I do anything more than hovering.
Varies on each model but my swash %'s are:
Ail: 55%
ele: 65%(up to 70 for really fast flips)
pit: 50%
For really smooth/tame hovering I'll drop ail & ele down to 40-45%, then each stick movement very slightly effects the heli.
But if you get into trouble you really can't slam the stick to recovery because you only get so much swash travel! Maybe that's the big difference between adding expo & lowering swash %...
newflyguy1 is offline        Reply With Quote
Old 01-22-2011, 07:19 PM   #9
banditpowdercoat
YOu changew your Tx every time you wana fly a different style? I like keepin the Swash full range for those times you need it. But ya sounds like Theres alot of different styles of setup, and I also need more stick time, I guess ALOT more stick time
Old 01-22-2011, 08:47 PM   #10
newflyguy1
Yeah I guess I would have to change the swash % in my Tx everytime I want more or less swash travel but lucky for me I have a few different birds & each is setup to do different types of flying! Really though it doesn't take more than a few seconds to bring up the menu & dial in a few % more or less, of coarse you have to land first. It's much quicker & easier to flip a switch that changes the expo rates but again I don't like losing my full stick range with expo.
Just personal preference really & to each their own. More stick time will probably equal less or even no expo eventually...
Old 01-22-2011, 09:41 PM   #11
banditpowdercoat
Oh does anyone run a - expo on the rudder? I'm finding in the SIM atleast, my rudder seems slow for me for gentle movements. I have at -20 for rudder and +30 for Aile and Elev. Am I weird??? LOL
Old 01-22-2011, 10:59 PM   #12
Dazhim
@ newflyguy How do u lose stick travel with expo I know u lose some servo travel with short swash %'s could you explain?
I use 10 cyclic 0 rudder anymore n the heli starts feelin to me like if i sneeze its outta there lol
Dx7s, 450 pro fbl,hs65mg,savox sh1357 BeastX
Big Rexy 600 R.I.P(rest in pieces)
MSH Prôtos: 500 fbl
IKON baaaby
mcpx real life SIM
Dazhim is offline        Reply With Quote
Old 01-23-2011, 04:19 AM   #13
tacomaster
none. sim is way more responsive. hovering the 400 is a piece o cake
tacomaster is offline        Reply With Quote
Old 01-23-2011, 11:51 AM   #14
Capt.Chip
I like 20 on cyclic and 10 on the tail in Idle Up and regular flight mode.
Blade 400 3D, 3-HS65MG, GY520, S9257, Traxxas Y on "Heads Up RC" 3 amp BEC, Stealth CF Blades, 2200 25C, T-Rex 500 LG, Phoenix Sim.,
DX6I, DX8, Blade MSR MCPX V2
TRex 600 ESP
AR 7000, DS610's cyclic, Quark gyro & DS620 on tail
Capt.Chip is offline        Reply With Quote
Old 01-24-2011, 04:46 PM   #15
desertblade400
I started with 30% and now don't use any expo.
Trex 500 ESP
desertblade400 is offline        Reply With Quote
