Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 01-23-2011, 12:53 PM   #1
lennyk
Default 760 problems
Hi Guys,
I have 2 760's which I have been using a while in 500's.
One day at the end of a flight one of the 760's starting drifting fast to the right in HH mode
Now it no longer holds in HH mode, I can adjust/trim it manually to fly in rate mode but even if it is trimmed for rate mode when I switch to HH it drifts badly.
Any suggestions ?
lennyk is offline        Reply With Quote
Old 01-23-2011, 05:45 PM   #2
pril250
Your advantage is having two of them. You are able to interchange to determine and verify whether it is the gyro, servo or heli (vibrations) causing your problem.
Blade400
pril250 is offline        Reply With Quote
