Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 01-27-2011, 12:03 PM   #1
arturoo1977
Default Upper battery tray
Hi all, I have a dumb question. When you use 2x 3s batteries, who do you fix upper battery?
Is there an upper battery tray accesorie?
Arturo
HK450V2, HK450Pro, GAUI Hurri425
arturoo1977 is offline        Reply With Quote
Old 01-27-2011, 02:20 PM   #2
PTcaflyer
HF MR Support
Default Upper Batt. Area
...Just put a large piece of smooth Velcro on top and use 4 straps...
Same for bottom...
PT
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote
Old 01-27-2011, 04:20 PM   #3
arturoo1977
Thing is where top battery goes, there is only both frame side edges. I can make a plate or something to fill that empty space between frames sides but should not glue it in case frame needs to be set appart.
Just wanted to be sure about this.
Arturo
Old 01-27-2011, 04:25 PM   #4
Mikej
When I used the plastic fantastic frame I used these http://www.readyheli.com/CHP-G071-Cu...y_p_32274.html - I have a couple of sets if you want to buy some ......
Mikej is offline        Reply With Quote
Old 01-27-2011, 04:44 PM   #5
PTcaflyer
HF MR Support
...Those look cool Mike !
I'm too cheap to pop for something like that...I just drape the velcro over the edges on top a little bit and it stays in place when I remove the batteries( with nearly full length fuzzy side on them).
Batteries are so big they wouldnt fit inside the frames anyway...
PT
Old 01-27-2011, 04:49 PM   #6
Mikej
Yeah - they're not cheap, but they worked really well - believe me, the batteries were going nowhere !!!!
