| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
So I recently upgraded my dampeners and put in some Youngblood dampeners ( http://www.readyheli.com/DAMPENERS9-...0_p_32420.html) and a new set of Mavrikk G5 Pro blades. Man there is defiantly more response in my collective. However, I have developed a slight wobble when in hover. Not sure what this could be caused by? When I installed me dampeners I checked out my thrust bearings which were still in perfect working order. My bird has not been downed since I built her last aug. Now the only thing I didn't check was the balance of the blades. They are tracking perfect though. Any ideas? Could the Dampeners cause this? if so what is the remedy? Thanks for any help.
Trex 700E AP Ship, PS1 3XPro Gimbal Trex 700Nitro Pro LE, DX7se, Blade MSR Blade MCP X,Blade 400 |
whats your headspeed?
T-Rex 450PRO V2, T-Rex 700E V2, T-Rex 500EFL Pro ICE100 Vertigo motor T-Rex 550 FBL BeastX, KDE/Neu, ICE100 |
Normal = 1850
Idle 1 = 1950 Idle 2 = 1980
that should be fast enough, i dont think you can run much more without over speeding the engine, those dampeners might be too firm, how bad of a wobble is it?
They shouldn't be too stiff, their designed to replace the stock dampeners directly. and the wobble isn't to bad just slight but enough to notice.
#6 |
Is it a wobble or a nod? Mine nodded in normal mode after installing Truebloods. Keep flying and the dampers will wear in a bit and stop nodding. Mine still nods during an auto if I lose any headspeed.
#7 |
I guess it could be a nod, it just kinda rocks back and forth in almost a circular motion. She's stable forsure but I was just concerned if it could cause any problems in the long run.
#8 |
What about blade tightness, does the weight difference of the G5's vs. the Aligns make a difference? Did you lube the dampers and spindle when assembled?
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
Not to hi jack the thread here. I'm building my 700 and I've installed lifeblood dampeners. Will these give me problems and do I need to put the aligns in there?
MCPX...Futaba 8FG Super....T-Rex 450.....T-Rex 500EFL Pro DFC Head, Mini V-Bar 5.0 Pro, ICE 75, and Scorpion 3026-1600, Edge FBL....T-Rex 700LE, O.S. 91HZ-R, SB-20, CGY750, DFC Head, Gryphon Regulator and Autobooster, BLS251, DS610's... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 |
Hard dampeners will do this until broken in. It's pretty common so don't worry toomuch about it.
All this means is you have to fly more.
Lynx Team Pilot GrandRC Field Rep BEASTX |
#11 | |
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 - All on VBar 5.3 Pro GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster |
#12 |
It's the new dampeners, I would not worry about it. It should be more pronounced at lower rpm, like in Normal mode.
Just keep flying it, bang some tick-tocks and they should start braking-in after a few flights. ![]()
At the precipice, we change! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team GrandRC |
#13 |
Well I think I can handle flying more!!
![]() Thanks for the info guys and no I'm not flybarless yet. Yes Bryan i did make sure everything was lubed up well. haha...........lube ![]()
