Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters
Hirobo Nitro Helicopters Hirobo Freya Evo Eagle Helicopters Discussion
Old 01-27-2011, 11:32 PM   #1
codfish124
Default Will a O.S. .46 work to swing 600mm blades?
ok so i got a hirobo .50..... it has a O.S. .46 motor in it and I'm having a hell of a time getting this thing tuned. i think the low end is good. New to nitro so i really don't know. I can punch the throttle and it doesn't bog down.
My question is am i straining the motor to much trying to push these 600mm blades? Iam only running 7+/- pitch and where it seems to run the best with lots of power it will over heat in like 2 min or less of flight. S so i ritchen it up a few turns and it just a turd with barely any power.
question 1: should I get 30% fuel as iv been running 15% will this help?
question 2: should i get 550mm blades and tone down the throttle curve?
codfish124 is offline        Reply With Quote
Old 01-29-2011, 11:22 PM   #2
Mike2112
It's hard to give advice without being there, but going with 30% and 550mm blades sounds like a good start. Blades being 1st. My Sceadu has an OS .50 hyper and I swing 600s. At 11 degrees pitch, she is maxxed-out so it's safe to say you need 550s.
Are all the bearings smooth, and is the belt the right tension? Also, is the motor's exterior clean? A dirty motor will not cool as well...adding to a power loss and over-heating...
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy
Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256
Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257
Mike2112 is offline        Reply With Quote
Old 01-30-2011, 09:06 AM   #3
321
Do you know if the OS46 is a heli engine? OS heli engines (vs. airplane engines) have bigger cooling fins on the head and carburetors that tune better in the mid-range.
I used to have a Raptor 30 "stretch" with an OS32 (later a TT39) and "600" blades and it worked OK, other than being low on power all the time. It was better for autos though.
Long live the Rebel L.
321 is offline        Reply With Quote
Old 01-30-2011, 09:18 AM   #4
MarkD
Team Taco Member
I would say 550 blades are to small for a 46. A 30 size runs 550mm with no problems
Mark
Morley F1 60 Max (OS 61LX-H), Hirobo SDX (OS 55HZ-H, GY701), Trex 450SE + some planks
MarkD is offline        Reply With Quote
Old 01-30-2011, 03:58 PM   #5
Mike2112
If he's over heating, blades would be cheaper than a new motor just to see. Maybe the motor is tired. I think you meant "A 30 size runs 550mm with no POWER". Even my 50 hyper with a hitori pipe and radix blades feels week compared to some of the electrics I'v flown...and it's a new motor and mint condition heli. I can't get over the E-powered helis these days. But my Hirobo is the best flying heli I'v ever flown hand down.
Old 01-30-2011, 04:48 PM   #6
codfish124
It is the heli motor I put 30% in it and up the pitch to 10 seems good
Sent from my T-Mobile G2 using Tapatalk
