| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Team Taco VP
OK doing my conversion to FBL now. I am using the mini V-Bar with the Align FBL head. This will be my first FBL setup
So before I put all the servo back in, any others out there with this setup and did you have to change the ball spacing on the cyclic servos? Thanks, Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Bob, I can't say for sure with the VBar ..but with the Micro beast you need to move one hole in to get the proper geometry if your using the 410 servo's..should be almost the same for Vbar
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
One hole in from flybar setup is correct (I had this setup on my first 450 Pro last year).
Edge Rotorblades Thor/Voltz Batteries 450 Pro V-Bar 130X |
Bob, no I left my servo ball spacing the same but I did follow Aligns FBL head set up for the lengths. As for the cyclic linkages go, I ended up leaving them the same length as the FB version but I believe Align calls for them to be a bit longer???
She flys great FBL, more aggressive and has a much crisper response you'll be pretty impressed. hey what servos are you using? |
Team Taco VP
I am using 5065MGs. The stock FB ball spacing is 13mm on the Pro with 410's.
ChrisH when you said one hole in, I assume on the 410 arms? Bob
#6 |
that's what i'm using and i didnt need to move them, you should be fine.
#7 |
Yes I am. When I get home later tonight I can measure them for you, however 11.5mm rings a bell...
#8 |
Team Taco VP
Cool thanks Chris....
Bob
#9 |
Bob,
The 2 sided servo arms or the Hitec's measure the same as the align 410's per side, same to same with the hole spacings. So if you used the outer hole from your build video just move in one.
#10 |
Team Taco VP
Cool thanks for the help..... Wanted to get the ball spacing right as taking off the servo arms on the pro is a beoch
OK another question. I notice some guys set for leading edge blade grip control and other use trailing. Which you guys prefer? Next question, how much cyclic pitch you guys run? I usually always maxed mine out when I was FB and could bind when at full pitch in a corner with cyclic. I never measured it but it was probably about 9. Bob
#11 | |||
(FBL) spline to inside hole: 12.5mm (FB) spline to outside hole: 15mm Quote:
Depends on the FBL controller, some like more than others. Since you're running the Mini V, go through the on-screen instructions to set up cyclic pitch (using Vstabi 5.0 it should be approx 8-9˚ if I recall correctly). Note that you can't actually check how much cyclic you are using in flight, you're just setting the max cyclic allowable for the unit.
#12 |
Most FBL heads are leading edge control, if that is any help.
You can adjust the cyclic pitch range through the software, can say 100% certain but I believe 6 is the normal for the control loop to function at its optimum. Mr Mel. over on the Mikado V-Bar forum could answer that for you
#13 |
I'll be going FBL on my Pro as well.... Leading edge is better for FBL because you do not want flapping in the head...otherwise it may tend to 'wag' or overshoot. A trailing edge blade is used in flybarred heads because you want this flapping...it also helps with the heli rolling in FF... but a FBL unit takes care of all that sort of thing.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
#14 | |
#15 | |
Team Taco VP
I do realize you cant measure how much cyclic your using in flight! That would be magical software if you could. Also I have watched MR. Mel's videos and understand the basics. I am now just looking for the tweaks and a little more detail for the Pro like the best ball spacing. I got that now thanks to you folks So one bummer I see is you cant adjust rudder gyro gain from the radio? I see why guys always have a laptop with them now... Bob
#16 | ||
#17 |
hey bob, i adjust my gyro gain on the TX in the gyro menu. i'm not fully understanding what you mean by you cant adjust it this way? I set mine up with 8 degrees on the s/w but then later went back with my pitch gauge and TX and put it at 10.
back to your rudder gyro gain... at the main screen of the vbar program you will use the mouse cursor to adjut the gyro for the aile/elv on the left of the screen and then use the TX to adjust the gyro on the rudder. you will have to make a big adjustments before you see it move but just watch the slider on the right of the screen and you will see some movement. one thing i had issues with after set up was getting the esc to engage, if you encounter this you will need to adjust your throttle end points to match your cyclic channels |
#18 |
^^^ the throttle issue applies if you are using sat rx... not sure if it happens if you use a standard rx
#19 |
Bob,
Assuming your running 5.0 Pro.. No option is "better" than the other, it's just a preference, if you don't want to bring the computer or have a control panel, then it's perhaps best to setup Gyro in Radio to be "Aux" which you can do. In the software you have to set "Aux->Gyro Gain" in the bank switching dropdown, and then you need to make note of which % in radio is what % in vbar.
#20 | ||
