| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
could you recomend a good starter for a t rex 600 with an align 55h engine my old starter just dosnt have the grunt to turn the engine over
many thanks dave |
Hobbyco Torqmaster 180 is what I use... I have it setup with two 7.4v NiMH batteries in series that are mounted to the starter. They also have the ones for the Makita 18v cordless batteries. I would prefer the Makita now that I have a drill set that uses those batteries, but wouldnt buy the batteries just for the starter.
the align starter is pretty nice..
I have a sullivan hi-torque starter.. Run it with an old 3s lipo.. Plenty of torque to turn the motor over, unless It's hydro locked.. in which case it's good that it doesn't have enough torque to turn over!
TRex 700DFC CC 120HV/VBar TRex 500 ESP/FBL CC Ice100, MiniVBar TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C |
#6 |
i got a used hobbico 90.. on a 7amp battery in a flight box NO problems here
Raptor 50 w/upgrades; HK500 w/Align parts; BeltCPv2 w/ trex style head; Belt CPX w/Trex style head. Still learning... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
Torqmaster 180, KSJ battery pack, two cheap 7.2V NiMh batteries wired in series, and a sullivan starter wand (Could get away with a much cheaper starter wand).
Team Miniature Aircraft USA Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion -Darrick |
#8 |
I use a hobbico with an old 11.1v 2200mAh lipo on it. Charge it once every few months. Plenty of power to start my 55.
T-Rex 600 Nitro Super Pro - OS .55 HZ Hyper, HR55 Pipe, AR7000, Gy611, S9256 Tail, Align DS 620s on Cyclic, 7.4v 3000 mAh FlightMax LiPo, MPI Regulator, RCE G600 Gov, JR X9303 JR Airskipper 50 - in a bunch of peices To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
I received mine as a gift, and haven't had any problems with it at all.
Warp 360 Spartan Vortex VX1 |
#10 |
#11 |
I use the Sullivan Dynatron starter with a 6s battery and don't have any problems...easily starts my 90's
I used to have the Hanger 9 HD starter but it went out after about 10 uses...piece of junk.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910 |
#12 |
Ive been useing a cordless drill with the same battery now for 3 years starting my 50's and 90's
#13 |
forgot about that...Just need to make sure that you have one that has an adjustable clutch on it so you don't push past hydrolock.
G-force makes an adapter, forget who else makes them. http://www.gforceheli.com/c291071_en...376/index.html
#14 |
what battery were you using?
Trex 700 dfc (OS 105HZ-R, Hatori Pipe, MKS HBL950, Futaba CGY750, MKS HBL980, Rail Mains, Rail Tail Blades) |
#15 | |
Bob |
#16 |
For the Sullivan, I use a thunder power 5000mha 25c. On the Hanger 9, just car battery.
#17 |
Have the align starter and it is a bit weak, almost burnt it up trying to start my heli one day before I learned about hydro lock, I couldn't get the damned thing to start, or even spin then I read the manual and discovered that motors can hydro lock, and remove the glow plug to remove the fuel trapped in the head. DOH oh well the align starter is a Pain in the arse had to re-wire the battery as it really sucks trying to get the deans disconnected from the battery.
Trex 600N LE, DX8, OS 50, 701, BEASTX Trex 550E FBL, STOCK Trex 450 Pro MKS DS95 BEAST X |
#18 | |
![]() Good solder joints are VERY strong. Just pull on the wires and the connector will come off in two seconds.
#19 |
I was contemplating getting the align starter. Looks really nice and compact but was put off by the price, so I tried my little Rigid drill from Home Depot that I use at work and boy was I impressed. My Hobbico 90 starter on 4 cells had a really hard time turning over my 600 nitros os 50 hyper when it starterd to get a little hydro locked. I had to always take off the canopy, undo the 2 in 1 clip and pull out the glowplug, but with the Rigid drill set to its lightest torque settings made this a thing of the past. So what I did was purchase another Rigid drill just for the heli since the other one I have is used for work. It cost 99 bucks and comes with 2 lithium Ion batts, a light, 15 minute charger,and a nice carrying case. Also one of the best things about it is, if it ever ever fails, Home depot will warranty if for a lifetime. My first one had a battery go bad so they just returned it and gave my my money back. I went right back to the tools coral and pick up a new one the same day.
#20 |
Nice Case and very compact.
