Go Back   HeliFreak > R/C Helicopter Support > JR Helicopters
JR Helicopters JR Forza, Vibe and Vigor Helicopters Discussion
Old 09-29-2004, 10:21 AM   #1
Ivan
Default What is the final say on the Vigor auto hub?
Well, it finally happened to me. My auto hub froze up, after inspection, I found that one of the needle bearings got sideways a bit and locked it up solid. Was quite a chore to get it off.
Anyway, I had to order a new one, and I am wondering what is the best way to keep it from locking again. I have heard hints ad rumors of this with the 90 engines, but I don't ever remember a good answer.
Oh well, it was still cheaper than a new crown gear!
I came, I saw, I hovered
Ivan is offline        Reply With Quote
Old 10-02-2004, 12:15 AM   #2
rchaas
Use a hardened main shaft (i use the scott gray mains) and keep the auto hub bearing well lubricated.
Robbie
rchaas is offline        Reply With Quote
Old 10-02-2004, 08:49 PM   #3
rstacy
I had this happen when I was running the OS 90. I never liked that engine. It semeed to vibrate a lot.
I have not had the problem since switching to the YS.
rstacy is online now        Reply With Quote
Old 10-03-2004, 01:28 PM   #4
Ivan
Yeah, that OS has caused me troubles from the get-go.
Old 10-04-2004, 11:05 PM   #5
mevigavant
I had a hardend shaft(not Scott Gray) and it locked up on me anyway! I switched the shaft and oneway. Everytime I got done flying I would add some drops of tri-flow to it before the next time I went up.. Once I forgot to do this before I flew and it locked up again but not as bad. what the hell. is this only with 90's? I too have an Os(c-spec) in my vigor. How does CY keep his from locking up?
mevigavant is offline        Reply With Quote
Old 10-05-2004, 09:01 AM   #6
Ivan
curtis uses older hubs from vigor standards. I would hope that JR is going to fix this soon.
Ivan
Old 03-18-2005, 04:14 PM   #7
UFO290
Are you referring to OS 90 hyperhead??? :cool:
UFO290 is offline        Reply With Quote
Old 03-18-2005, 05:28 PM   #8
rstacy
I did have a Hyper Head on that engine.
It didn't help with the vibration.
Old 04-12-2005, 11:30 AM   #9
wolfdad
The vibration issue with the OS is pretty much across the board. Only improvement I was ever able to see was with the Viperhead installation. I have a single Viperhead on one and the dual on another and, quite honestly, that was the only improvement I ever saw, but that, in itself was a significant one.
On the lock-up with the auto hub, I have had several problems with my Voyager 50's and the one thing that I have started doing is, on a regular basis, pulling the hubs apart, cleaning them, then re-lubricating them with "white grease." On my Vigors, I have yet to experience the problem, however I know it exists...kinda' like the tail rotor gearbox separation....I just take folks word for it and put the metal ones on.
Doc
"there are those who have...and, those who will"
AMA #70068
IRCHA #2117
Rotary Turbine Waiver #105
wolfdad is offline        Reply With Quote
