Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 02-07-2011, 04:54 PM   #1
Bart101
Default Quick question about the 4225-610KV :)
Hi all,
Fist of all, will the Scorpion HK4225-610KV fit the Fusion 50?? As this is a 10s motor, what pinion should I run?? Just stick with 14t?? And as it's a 6mm shaft, what pinion should I use?? As the ones that come with the kit are 5mm
Cheers,
Shaun.
Bart101 is offline        Reply With Quote
Old 02-08-2011, 08:56 AM   #2
OUTRAGE RC
Shaun,
the 4225 is too big, we would not recommend that. However you can try to install it, it will fit with motor mount adjustment.
For pinions 6mm diameter and 0.8M, please check out
http://www.helidirect.com/advanced_s...pinion&x=0&y=0
you can test with 14T first.
Outrage Rc
www.outragerc.com
OUTRAGE RC is offline        Reply With Quote
Old 02-08-2011, 12:08 PM   #3
Bart101
Hmm, I think I'll just stick with the 4025-550 on 12s... Don't really want to start grinding my motor mount!!
Thanks anyway!!
Cheers,
Shaun.
Old 02-08-2011, 03:13 PM   #4
akamullen
I was thinking about using my 4035-530 on 12S, I have one in my 700E right now and was going to get a 4035-500 to put in the 700E. I wonder if the 4035-530 would be over-kill for the fusion? Any comments would be appreciated as my fusion will be here on Friday... The 4035 is taller but don't see a problem fitting...
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 500/630/770 * TREX 450DFC @ 6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all
akamullen is offline        Reply With Quote
Old 02-08-2011, 03:29 PM   #5
NT Flieger
Why is the 4225 too big???
I have this motor and I will install it in my Fusion.
Thomas
NT Flieger is offline        Reply With Quote
Old 02-08-2011, 08:09 PM   #6
akamullen
Thomas
I dont see why not. there seems to be room for it..I could be mistaken though as my fusion is not here yet.. Only going by the pictures I have seen... Let us know how it goes with the install...
GAUI X5 / X7 *
