Old 02-07-2011, 08:35 PM   #1
Pfloyd
Default Transmitters
Will the LP5DSM work with this heli?
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote
Old 02-07-2011, 08:46 PM   #2
SYMAWD
All DSM2 TXs will bind with it, but you wouldn't have Idle Up/ Throttle hold with the LP5DSM or DX5e (but HH recommends it?) A DX4e, DX6i ,or higher is what I would recommend.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote
Old 02-07-2011, 08:49 PM   #3
Maverick YOW
Not supported; minimum is the new four channel and DX5e upwards...
Maverick YOW is offline        Reply With Quote
Old 02-07-2011, 09:07 PM   #4
Pfloyd
Isn't the DX5e about the same as the LP5DSM?
Old 02-07-2011, 09:19 PM   #5
SYMAWD
I'm pretty sure you can get Idle Up with the DX5e. Technically an MLP4DSM will work, but what's the point if you don't have IU or TH? Just get the RTF or get a DX6i or higher so you can bind all of your DSM2 ultra micros to it
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 02-08-2011, 04:12 PM   #6
toys2cars2toys
According to the manual you do get IU and TH with both the 4E and 5E
You bind the heli in a different way when using the non computer TX's
The throttle channel controls both motor and pitch, using pre-programmed (onboard) throttle and pitch curves
From what I can make out the fifth channel Hi/lo switches between Normal and IU modes
Even the DX4E has IU mode so it must have a fifth channel
Somehow the trainer switch is used to give TH mode and there is a reset procedure as it is a non latching switch
My guess is that as the LP5DSM has the same channels and switches then it may well work but to switch to IU, you would have to rotate the 5th channel dial..not sure about TH being the same but it should be
If using a computer TX, regular "big" heli pitch and throttle curves are programmed into the TX
toys2cars2toys is offline        Reply With Quote
Old 02-08-2011, 10:15 PM   #7
Pfloyd
Doesnt the LP5DSM have a fifth channel? The rotating knob on top? Also, I know TH is throttle hold, what is IU?
Old 02-08-2011, 10:19 PM   #8
PittJitsu
Idle Up= IU
PittJitsu is offline        Reply With Quote
Old 02-08-2011, 10:22 PM   #9
Mojappa
Idle Up/ Stunt Mode- Usually 100% throttle throughout the entire stick range (flat throttle curve) and the collective stick is only changing the pitch of the blades. Pitch range is generally -10/0/10 give or take a couple of degrees. This is why chopping the throttle is a bad habit when moving up to CP's, it may save the MSR but it will only slam a CP heli harder.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote
Old 02-08-2011, 11:15 PM   #10
dezrat27
Default mcp x settings
I'm excited about the new bird as I see many are, went ahead and programed by dx6i settings from the manual just now. My question is why is it running the swash setting at 1 servo 90 d. instead of 120 d. 3 servo like My SR? Just guessing but is it the FBL system? Whats up with not having trim? wierd
dezrat27 is offline        Reply With Quote
Old 02-08-2011, 11:21 PM   #11
Mojappa
The normal swash mixing is done in the 5-1 with this. Kinda bummed about that, it would be nice to be able to set min/max pitch and swash throw to my liking. I'll reserve judgement about the chosen preprogrammed settings for when I've flown one.
Old 02-08-2011, 11:22 PM   #12
SYMAWD
The swash mixing is all handled by the board, hence the 1 servo setting.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 02-08-2011, 11:26 PM   #13
SYMAWD
They are only calling this a 3 in 1 board. RX, ESCs, and gyros.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
Old 02-08-2011, 11:38 PM   #14
Mojappa
the board
Old 02-08-2011, 11:46 PM   #15
dezrat27
oh! thanks good responce time guys. so what about the trims not being used?
Old 02-09-2011, 02:41 AM   #16
merlin3
you can use the trims if you need to, to trim out the heli but its normally not needed.
Team Horizon
merlin3 is offline        Reply With Quote
Old 02-10-2011, 09:28 AM   #17
Vinger
No trim on a FBL heli, as the 5(3)-1 unit will see it as an input and the heli will roll or pitch continuously...
Gaui R5, Henseleit TDR +TDR2, Banshee
Kontronik ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Vinger is online now        Reply With Quote
Old 02-10-2011, 10:48 AM   #18
merlin3
you can trim it if need be
Team Horizon
Old 02-10-2011, 11:02 AM   #19
mediclavina
+1.
On my FBL GAUI 200, I did all the trimming on the SK-720. All transmitter trims are kept on neutral.
GAUI EP-200 V2 FBL, Blade Nano CPX, Blade mCP-X, Hirobo SRB Quark, Blade mSR, Blade mCX
mediclavina is offline        Reply With Quote
Old 02-10-2011, 11:06 AM   #20
Mojappa
Besides knowing the designer and actually flying one, what makes you think you know what you're talking about. I speculate you're wrong. hehe
