Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Others
Others Walkera Other Models Helicopter Support
Old 02-10-2011, 04:19 AM   #1
acehigh
Default V200D01 problem
Hi!
My heli is leaning constantly to the right and I need to use my right stick (mode2) to the left to even the heli, so its not going to the right. What is wrong?
I fly with a mate who got the same heli, and his heli is even and not going to the right.
I've tried to trim the transmitter but it didnt help. Someone said I have to set FBL system. How to do that?
I am new to this hobby and its my first heli.
-acehigh
acehigh is offline        Reply With Quote
Old 02-10-2011, 06:52 PM   #2
Blayd
You also need to check and see if the swash plate is level. Sometimes they arent set exactly right from the factory, and if your going to be flying these, its a good thing.. a must, to know how to check and level your swash. If its not level, your going to have issues. There are a ton of set up help guides on this forum, look through them, and see if your swash is level. I would advise checking all your bolts and nuts for looseness. ( alot of us use blue Loctite on all metal to metal bolts and nuts)
Blayd is offline        Reply With Quote
