Old 02-13-2011, 07:13 PM   #1
Diesel
Default 6s setup w 170 main=what motor?Xera any good??
I am completely aware of the 8/10/12 s setups but want to keep mine at the stock 6s setup. My 600XL motor went buy buy today, and I would like to know what RECENT setups work great with a 6 s setup. I would like a little more "umph". I am not stuck on Align/Scorpion/Neu and am open to ideas. I am running a CC100 esc. I have a ton of the 170 stock main gears and would also like to stick with that as a main gear. I just want to hit head speeds of about 2050/2100 and not bog too badly. I am running Turningy 35C batteries. I remember hearing something on XERA motors being awesome, any thoughts on this one? I really appreciate the help/opinions fellas.
Diesel is offline        Reply With Quote
Old 02-13-2011, 07:39 PM   #2
Cheetah62
Don't know anything about Xera motors.
IF you decide to go the Scorpion route I would suggest you look at the Hyperion line.
Hyperion motors are made by Scorpion with matching specs, but have better bearings that don't have the high maintenance requirements that the Scorpions are so well-known for.
Generally they're not easy to find online, but if your LHS carries Hyperion products they should be able to get what you need. Prices are the same as Scorpion.
http://www.hyperion-world.com/products/type/1
TREX 600ESP, Outrage G5, mCPX, CX3
Phoenix Sim - Mastering flight one crash at a time.
Cheetah62 is offline        Reply With Quote
Old 02-13-2011, 07:42 PM   #3
Diesel
Thanks Cheetah! Would this be a good replacement or would you recommend a lower kv?
HP-HS4025-1100
Hyperion HS 4025 High RPM Brushless Outrunner Motor (Kv 1100)
Old 02-13-2011, 07:44 PM   #4
Bendero
I am building a similar setup as you. CC120HV esc, 170 main, 6 cell lipo, and am using a Hyperion 4025 1100 kv motor. In the process right now of figuring out which pinion to use. Anxious to see the improvment over the 600L
Bendero is offline        Reply With Quote
Old 02-13-2011, 07:46 PM   #5
Diesel
Bendero, Cheetah wasnt kidding -I have been searching all over for that motor-nowhere in stock!!! Where did you get yours?
Old 02-13-2011, 07:58 PM   #6
Bendero
A friend of mine gets them from a dealer out west.. he gets his mikado stuff there. I'll try to find out. I had him get me a hyperion charger as well, because i couldn't find one around
Old 02-13-2011, 08:29 PM   #7
Tisondm
The Scorpion 4025-1100 is an awesome replacement for 6S. Runs cool, efficient, and more power than the Align motors.
JR X9503
TREX 500 ESP FBL, Skookum SK720, Scorpion 3026-1600, 14T
CHP TREX 600 ESP FBL, SK720, 8S, Scorpion 4025-740, 13T, WR Bec
TREX 700E FBL, SK720, 12S, Scorpion Comm 130A ESC & 4035-500 , 12T, WR Bec
Tisondm is offline        Reply With Quote
Old 02-13-2011, 10:17 PM   #8
Diesel
Where do you get pinions for the Scorpion 6mm shaft motor that are compatible with the Align main gear?
Old 02-13-2011, 10:25 PM   #9
Cheetah62
http://www.helidirect.com/advanced_s...eywords=pinion
Old 02-13-2011, 10:39 PM   #10
Diesel
Thanks fellas. Just ordered the HK4025-1100 and 14 T pinions. Will I need a 15T or will that be a bit much for the 6s setup???
Old 02-14-2011, 03:04 AM   #11
Andy01
Pity. I have a X-era 4030-470kV motor in a 700 sized scale Long Ranger. Very nice motor, really smooth, quality bearings.
I wanted a 4025-560kV X-era for my 4 blade 600 Seahawk, but could not get one in stock at the time. Had to settle for a similar Scorpion, and by the time I got a 6mm shaft and ceramic bearings they were almost the same price.
Colin
Vario Long Ranger 700e
Seahawk 600 - work in progress
Atom 500
Trex 450 SA hybrid
Andy01 is offline        Reply With Quote
