Old 02-15-2011, 11:42 PM   #1
Inverse
Default V2.0, differences?
Just trying to figure out if it's worth buying the USB cable and updating to V2.
What are the differences? V1 seems fine to me.
Inverse is offline        Reply With Quote
Old 02-16-2011, 12:11 AM   #2
Blade~400~er
actually as i understand it the units going out now are all V2, the usb device is for getting updates down the road as the MB system is very new, i mylsef am looking fowad to some sort of multi-blade programming
| TREX-500 SUPERCOMBO|
| BLADE-400 | MD500D Fuselage w/ Lights |
| TREX-450-SE/V2 |Align 3GX|Fusuno MD500E Fuselage|5 blade|
Blade~400~er is online now        Reply With Quote
Old 02-16-2011, 08:01 AM   #3
Peter
I don't think it's really worth the effort to upgrade to V2..
I did ; all I noticed was a faster tail rate , that I slowed with Rudd ATV anyway ...
I can upgrade yours if you like!! Will need to d/load the V2 manual too ...
I'd be surprised if even the proposed PC software to set up the beastX will generate an acute need to get the USB dongle; I reckon the BeastX is brilliant as it is/was....
Peter
Furion 6 FBL ; E,N and G Whiplash FBL ; 3 Spectra G FBL ;3 Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: Aeolus KME 60 , 2 Velocity 50's FBL; few 500's.. All BeastX ; guided by XPS .
Peter is offline        Reply With Quote
Old 02-17-2011, 01:58 AM   #4
styndall
I still run both mine on V1, I updated to V2 but found I had more sucsess getting the tail to hold well on V1 and the pitch seems too touchy around center stick on V2. I had no real reason to move to V2, I saw no benefit given that I use a receiver and decided to stick with V1 for now, it works flawlessly as far as I am concerned.
Mikado Logo 600 - 10s HKIII 4035-560, Edge 623 FBL, BLS451, BLS251, MSH iKON
MSH PRÔTOS 500 Stretch - 6s HK 3226-900, Edge 473 FBL, MSH Brain
styndall is offline        Reply With Quote
