Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 02-16-2011, 07:01 AM   #1
silverbullet
Default >Gil Rothmayr 1St hands on the Fusion 50
Ok Guys, this is the first Vid from the Swiss_Team Outragepilot Gil.
i think it looks fantastic..
Setup is:
X-era Motor 4025-560,3Y
12T Pinion, (running lower Head Speed und still performing exelent.)
Jive 80HV
Mikado mini V-Staby.
12S 3300mha-25C Desire Power Lipos.
MS-Composite Campion Blades.
The temp after the flight ,was straight 33Degree Celcius (Motor-ESC and Lipo all the same
mesured with the Temp Gun.
Enjoi
time to roll the bass
silverbullet is offline        Reply With Quote
Old 02-16-2011, 07:15 AM   #2
HoffY
Very nice silverbullet!
You say low head speed... may i ask roughly what speed that means? i'm thinking of running a very similar system to this one and would much rather lower headspeeds because i don't think you need ballistic head speed with larger heli's and still be able to lay it down. Get more flight time to boot.
HoffY is offline        Reply With Quote
Old 02-16-2011, 07:30 AM   #3
silverbullet
it was around (2000rpm) , we was calculating it with a Headspeedcalculator programm.
12T Pinion and 560KV for the motor. on 12 S ESC open @ 70%
Old 02-16-2011, 08:23 AM   #4
chrlsdim
2000t rpm rotor speed is not slow
on this video 1800 rpm
[YOUTUBE]
T8FG T-Rex 450Pro FBL(SK720) & T-rex 550e-FBL(BeastX)
FUSION 50+Jive80HV+HK4025-550+SK720+BL9180/88
Velocity 90+YS91Sr3DS+GY701 +Torq 9180/88
GOBLIN+CGY750+Torq9180/88+YGE160HV+Hacker A50.12L
chrlsdim is offline        Reply With Quote
Old 02-16-2011, 09:30 AM   #5
silverbullet
, please consider its not mesured with a laser just calculator prg,,
(By the way we stickbang the t-rex 600 with 2400rpm ) so 2000 is slow for me )
Last edited by silverbullet; 02-17-2011 at 05:56 AM.. Reason: some may not get my piont,:) nevermind
Old 02-16-2011, 11:14 AM   #6
im4711
it is surprising how easy you can misjudge it by sound. I was running mine with 2400 and with 2100 -> both sounded almost th same and my first feeling was it is too slow. Reality 2400 is still way to fast. So I will dial it down a little bit this weekend.
im4711 is offline        Reply With Quote
Old 02-17-2011, 05:25 AM   #7
HoffY
silverbullet,
Thanks for your estimate of head speed. Its great to hear you say it was around the exact same speeds i was hoping to hover in (pun intended! ).
If the pro's of yesteryear could fly how they did with those "low" head speeds and seeing your flight (which was really great stuff) just confirms it even more. I'll convert it into more air time.
Old 02-17-2011, 10:58 AM   #8
im4711
I would love keeping mine at 2400 rpm -> only issue I saw was that Outrage recommends max head speed of 2200. So I will dial ours down and see how it is doing. I might even run it about 2300 at the end.
Will set the TRex 600 the same with same electronics just to see how they compare in real.
Old 02-17-2011, 02:53 PM   #9
silverbullet
one more from Gil, with more headspeed,, look bloody fast to me
Old 02-18-2011, 04:34 PM   #10
DominicD
The Capi - HF Support
I like his flying style, very nice flying.
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 02-19-2011, 03:13 AM   #11
akamullen
When you say 560kv, what motor? the 4035-560kv?
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 500/630/770 * TREX 450DFC @ 6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all
akamullen is online now        Reply With Quote
Old 02-19-2011, 05:43 AM   #12
silverbullet
Nope, the X-era 4025-3Y-560KV 8P,,the infos are at the beginning from this tread,
cheers
