Old 02-21-2011, 03:33 PM   #1
Elios000
Default 473mm blades?
any one thing the 500 could swing some 473mm blades? or would they be to long/heavy?
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Reply With Quote
Old 02-21-2011, 03:39 PM   #2
lankey
I wouldn't use 473mm on a standard 500.... that's quite a bit longer than the stock 425's. You'd end up having to change your gearing, and there will be a heck of an increase in the chance of boom strikes!
Then I'd ask why would you want to?
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote
Old 02-21-2011, 03:45 PM   #3
Elios000
one of the short comings of the 500 has been its heavier then avg rotor disk loading
running a longer blade like a bigger wing would lower the load per sqr in.
and why does any one run longer blades 5cm isnt that much really ether well slight less 4.7cm over stock 425D's i run the Edge FBL are 423 but they just came out with a 473 FBL
10cm bigger rotor disk would bring it up to 1m on the dot just about
DX8
AMA#948801
Old 02-21-2011, 04:03 PM   #4
dannylightning
i think you are on to a good thing here. if you try this please let us know how it goes.
i would think there would be no problem adding a blade that is only slightly bigger. but i could be wrong..
Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more.
dannylightning is offline        Reply With Quote
Old 02-21-2011, 04:10 PM   #5
Elios000
did some quick check might be just a hair to long a 450 or 445 mm blade would be about perfict really wonder why no one makes them in that size
if you could stretch the boom ~20mm they would work hmmm....
DX8
AMA#948801
Old 02-21-2011, 04:47 PM   #6
im4711
good luck on the 473 mm blades. They are simply way too long.
I run 430 mm blades and not sure why I would go any longer. The main blades and tail blades look pretty close already. It is a 500 and not a 550 size heli you are dealing with. If you extend the tail boom you possibly could do it. However even than you would need to get a stronger motor and with it a different ESC ...
im4711 is offline        Reply With Quote
Old 02-21-2011, 10:49 PM   #7
Mike2112
To those wondering why someone would want to do this, because of the flight characteristics. A light disc loading flies so much nicer (of course you may prefer otherwise for whatever reason). I stretched my 450 and would never go back. The 500 (ESP) is a pig and needs a diet IMO.
Mine flies nicely but a set of 450mm blades is what I crave too...just to lazy at the moment to do it. Look at how a mikado logo 500 flies...they are the shit!! Again, preference only. You may want to throw a 400mm flybar on to help speed the cyclic back up with bigger blades if you still have one. I did this on my 500 (Hirobo 390mm FB) and it is MUCH more stable in wind AND quicker on the cyclic.
Try experimenting on a sim...it will then be clear why!
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy
Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256
Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257
Mike2112 is offline        Reply With Quote
Old 02-22-2011, 08:38 AM   #8
lankey
Most of us knew the 500 has high disk loading before we got the birds. Not saying don't go to 447mm, but certainly expect to have to make modifications as that's a fairly hefty 11.3% increase in blade length.
I'd look forward to a flight report if you did do it.
450 PRO, 500 ESP
Old 02-22-2011, 05:41 PM   #9
dannylightning
not every one that gets one of these even knows what disk loading is lol.. i kind of understand it now but i did not have any clue when i got my 500
Old 02-23-2011, 11:04 AM   #10
sarmeneau
I still don't. LOL well, kinda do.
Trex 500 ESP DFC FBL
BLADE 130X
GOBLIN 630 CC 120HV, Scorp 4225 610Kv, Outrage servos, Skookum SK720BE GPS combo
sarmeneau is offline        Reply With Quote
Old 02-24-2011, 08:13 AM   #11
khymlawrence
whats this disk loading? high or light? thanks.
khymlawrence is offline        Reply With Quote
Old 02-24-2011, 10:47 AM   #12
dannylightning
here is my explination, if a helicopter has really good disk loading it fly's a lot better. if it does not have good disk loading it does not fly as good and i know the disk loading on the 500 could be a little better.
hope that clears it up for every one
Old 02-25-2011, 01:36 AM   #13
khymlawrence
Default disc loading
courtesy of wikipedia..
Disc loading of a hovering helicopter is the ratio of its weight to the total main rotor disc area. It is determined by dividing the total helicopter weight by the rotor disc area, which is the area swept by the blades of a rotor. Disc area can be found by using the span of one rotor blade as the radius of a circle and then determining the area the blades encompass during a complete rotation. As the helicopter is maneuvered, disc loading changes. The higher the loading, the more power needed to maintain rotor speed.[3]
Increasing the weight of a helicopter increases disk loading. For a given weight, a helicopter with shorter rotors will have higher disk loading, and will require more engine power to hover. A low disk loading improves autorotation performance in rotorcraft.[4] Typically, an autogyro (or gyroplane) has a lower rotor disc loading than a helicopter, which provides a slower rate of descent in autorotation.[3]
now i got it....
Old 02-25-2011, 07:09 AM   #14
snjbird
Disk loading = float... if your disk load is high the machine will "feel heavy" sluggish stops, slow starts over shoots, But the heli will be more stable in the wind. Lite disk load means hang time and sharper stops, quicker acceleration but more susceptible to wind and turbulence.
snjbird is offline        Reply With Quote
Old 02-25-2011, 09:12 PM   #15
Mike2112
now i got it....
That is from the FAA rotorcraft flying handbook! Nice. I love the floaty looking helis...they look so great...like UFOs!
Old 02-26-2011, 02:31 PM   #16
whisperdancer
The Trex 500 would benefit the most from 470mm blades.
It always has been a heavy dog.
Unfortunatelly, the small diameter boom doesn't allow the tail to be stretched.
Look at the MSH protos stretch. It flies much bigger than before with only 40mm more on each blade. Although the increase in blade lenght is small, the increase in outer area is very big. The blades are also wider. Same motor, same ESC.
When I had my trex 500 I searched for the stretch possibility, but without any sucess.
MSH Prtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
Old 02-26-2011, 04:09 PM   #17
mumpas
look here!
http://www.elyshop.com/store/dettview.php?id=13302
mumpas is offline        Reply With Quote
Old 02-26-2011, 09:01 PM   #18
Mike2112
Originally Posted by mumpas View Post
that looks like the answer. now who knows what motor/lipo/pinion, and esc would work best?
Old 02-26-2011, 11:03 PM   #19
Elios000
hmm maybe one for the scopion or if you can find one one of the CC motors and a 14 or 15 thooth
75amp ESC would do it maybe 8S? or to heavy?
DX8
AMA#948801
Old 02-27-2011, 04:19 PM   #20
mumpas
neumotor kde 1708h/1y n2 battery4s http://www.hobbyking.com/hobbycity/s...dProduct=11916
thooth 15t, esc esc cc ice 100
file castel creation ice 100 head speed 2460 2550 2700
