Old 02-22-2011, 03:03 PM   #1
s002wjh
Default trex 600 landing skid/tail fin
can these parts fit on trex 500 to help balance or tail strike? also what other parts can be substitute on 500 for newb that crash more due to mistake etc that will given durability or balance.
s002wjh is offline        Reply With Quote
Old 02-22-2011, 03:05 PM   #2
horigan
Readyheli or Helidirect sell a longer 500 tail fin that does a good job of keeping the tail rotor off the ground.
Rich
Synergy E5S VBar
Synergy E7 VBar
horigan is offline        Reply With Quote
Old 02-22-2011, 03:40 PM   #3
jtjohn1
The 600 skids will fit with just a minor modification to the skids (The holes don't line up so you have to drill your own holes on the skids)
I like the skids because they give you a wider base to the helicopter plus gives you a little higher stance (I put the longer tail fin on and it was REAL close to the ground with the 500 skids but with the 600 skids it looks like stock height again)
Logo XXtreme, Kosmik, Pyro 800-48L Futaba 157s/256. Henseleit TDR, Pyro 700-52, 120 Jive, V-Bar 5.3, BLS253/251. Logo 600SE, Scorp 5020-450KV, 120 Helijive, Futaba 451s/251. Logo 400, Align 510MGs, JR 8900G, Kontronik Jive 80+ LV,Mini Pyro 400-14,
jtjohn1 is offline        Reply With Quote
Old 02-22-2011, 10:15 PM   #4
Corvette & Copter Guy
As a noob I had fear of a tail strike. I made a longer fin from some lexan I had laying around. I gave it a good sanding and painted it the same yellow as my canopy. You can tell its "home made" but until it breaks or I get better...its good enough for now.
LOGO: 480XX, 550SX, 600, 700, 800XX
230s NIGHT, CONVERGENCE, COMBAT, ZIPPER
DPL8, KONTRONIK, MEANWELL, NEO, VCONTROL
Corvette & Copter Guy is offline        Reply With Quote
Old 02-23-2011, 10:32 AM   #5
s002wjh
what about 600 tail fin does it fit?
Old 02-23-2011, 04:40 PM   #6
horigan
I don't think the bolt holes match up. Not an insurmountable problem though.
Rich
Synergy E5S VBar
Synergy E7 VBar
Old 02-23-2011, 04:51 PM   #7
Rick Dizzle
I run the Fusano XL fin for the Trex 500 and sadly it is not much longer than the stock ESP fin...See pics:
I am lucky enough to be able to take off and land from a paved runway or a cement heli pad at my local field, so I have been blessed with no rear tail-blade to ground contact thus far! Fingers crossed as I probably just jinxed myself...LOL!
Trex 500 ESP w/ KBDD Tail blades and paddles
Trex 600 Nitro DFC/ OS 55HZ limited edition
Phoenix 5.0 Sim, DX9
Rick Dizzle is offline        Reply With Quote
Old 02-23-2011, 06:22 PM   #8
cboo
I bought an extra long tail fin from Grandrc that is orange. It's about a half inch longer than the stock. Where you fasten it to the verticle holder you may need to add a washer or you can as I did trim a small piece of the fin near the tail boon so it fits just right.
cboo is offline        Reply With Quote
Old 02-23-2011, 06:37 PM   #9
Rick Dizzle
cboo: what brand is it? I would love for mine to still be a little longer.
Old 02-24-2011, 09:02 AM   #10
Larry227
That doesn't look like the XL fin to me. The one I have is clearly 15mm or more longer.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote
Old 02-24-2011, 09:09 AM   #11
Larry227
yeah, mine's actually 20mm longer
Name:	xl_fin (Medium).JPG
#nodroneshere - 104
Old 02-24-2011, 01:01 PM   #12
Rick Dizzle
Man that is weird...I checked my invoice and it said XL...I am going to order another XL in a different color and see what happens....
Old 02-24-2011, 07:22 PM   #13
Larry227
I ordered mine a year ago when I built my kit. I'm sure at the time they were advertised as 20mm longer (which mine is) but now I only see 15mm longer. Odd.
I even looked at the old invoice online and it shows it as an XL but no part number.
#nodroneshere - 104
