Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 02-27-2011, 12:17 AM   #1
ntwaddell
Default Governor Sensor
Did anyone have to file out the holes to mount the governor sensor? I see on finless's video's he did to make it closer to the clutch bell. I'm wondering if i have to do the same thing.
Goblin Urukay Competition
Align T-Rex 450 Pro FBL
Align T-Rex 700 Nitro FBL
dji F-550
ntwaddell is offline        Reply With Quote
Old 02-27-2011, 09:16 AM   #2
CoolKD
I just kept it stock, works fine for me.
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
CoolKD is offline        Reply With Quote
Old 02-27-2011, 11:05 AM   #3
Finless
Team Taco VP
My 700 kit was the first out so things were not perfect. I understand they solved that after my build.
Bob
Old 02-27-2011, 11:08 AM   #4
ntwaddell
ah, got it.
http://helifreak.com/showthread.php?t=283209
I'm having issues with my governor, so i'm checking out all options
dji F-550
Old 02-27-2011, 01:57 PM   #5
cmassa
I recently had the Align governor fail completely. When I would go to idle up the motor would shut down. It would also shut down randomly even when already on the governor. I replaced the sensor with a backplate sensor and it did the same thing. The vbar governor software finally came out and I'm up and running again.
Chris
cmassa is offline        Reply With Quote
Old 02-27-2011, 02:11 PM   #6
ntwaddell
hmm interesting. mine is weird, i can get the magnet light to come on. when i idle'd up, it sounded like it started to work then just fails
dji F-550
Old 02-27-2011, 03:31 PM   #7
TT
I had to file them out on my LEs. I also had to reposition the magnets to be slightly above being flush with the clutch bell (that was NOT fun since I had to do it on two LEs that were built at the same time).
TT is offline        Reply With Quote
Old 02-27-2011, 03:41 PM   #8
ntwaddell
humm, here is a picture. mine is pretty darn close
so maybe if this doesn't work I will just try another sensor
dji F-550
Old 02-27-2011, 05:31 PM   #9
CoolKD
You are sure you got the polarety of the magnets correct?
One with north facing up and one with south faceing up.
Also My magnets are not as deep seated as your are. Mine is sticking out a tiny bit.
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
Old 02-27-2011, 05:32 PM   #10
ntwaddell
yup, polarity is correct. i get the green light on one, but not the other.. yeah i pushed them all the way in. maybe i shouldn't have
dji F-550
Old 02-27-2011, 05:53 PM   #11
CoolKD
Well it's regestering your magnet, so that should be good.
What radion are you using?
Whats your end points values on the throttle channel?
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
Old 02-27-2011, 05:59 PM   #12
ntwaddell
hmm that's what i figured. i flew it and it seems like its kinda working, but it is still logging that error.
dji F-550
Old 02-27-2011, 06:13 PM   #13
CoolKD
I had GOV trouble at first too, but my problem was that the travel limits I had set for the throtle servo was to far away from +100 - 100 and that made the GOV not work propely.
Check this thread out, allot of good info on the Align GOV
http://www.helifreak.com/showthread.php?t=49362
EDIT.. Your not using Align GOV are you?
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
Old 02-27-2011, 06:19 PM   #14
Helico-pteron
I did not have to adjust mine, but my Align gov failed twice during the time it was on the heli.
I have since installed a GY701 gov unit.
Helico-pteron is offline        Reply With Quote
Old 02-27-2011, 06:41 PM   #15
ntwaddell
align sensor on a V-bAR
dji F-550
Old 02-28-2011, 11:37 AM   #16
TT
Yup. Been there, re-done that. Twice.
Old 02-28-2011, 12:35 PM   #17
ntwaddell
argh, how can i get them out then?
dji F-550
Old 02-28-2011, 02:36 PM   #18
CoolKD
I suggest buying a new clutch bel and new magnets, they arent that excpesive.
I would think getting those magnets out would destroy the bel or damage it..
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
Old 03-03-2011, 04:52 PM   #19
AFjetmech
If you don't want to wait for new parts, drill a small hole under the magnets and tap them out.
AMA# 902812
More stuff than there is time to fly it.
AFjetmech is offline        Reply With Quote
Old 03-03-2011, 04:56 PM   #20
ntwaddell
yeah i might.. on another thread someone recommended drilling a small hole anyways to let the air/epoxy out when you glue it. whats the easiest way to get that clutch bell out on a t-rex anyways? I haven't even taken mine apart since i assembled it.
dji F-550
