Old 02-27-2011, 08:21 AM   #1
blackcataps
Default How best to check pitch settings etc
Ok. Watched lots of videos and asked around but still consider the following my weak spot when setting up flybarless beastx helis. How do you check pitch settings accurately? Does the align tool work with a piece of flybar in it or is there better options? Been told of various ways but none seem to make much sense over the align flybar tool. Any ideas or pointers be great. Has finless done a flybarless video?
blackcataps is offline        Reply With Quote
Old 02-27-2011, 12:27 PM   #2
Euwan
U could just buy a digital pitch gauge by rclogger that is what I use and it works a treat
Euwan is offline        Reply With Quote
Old 02-27-2011, 01:09 PM   #3
JustPlaneChris
All you need is a ruler and this spreadsheet:
http://www.helifreak.com/showthread.php?t=259188
Chris Boultinghouse
Team MSH USA | Team Lynx Heli
JustPlaneChris is offline        Reply With Quote
Old 02-27-2011, 01:10 PM   #4
turkana
Pitch gauges like this one work on bouth helis FB and FLB I have a similar one and love it!
http://www.centuryheli.com/products/...&currentid=452
turkana is offline        Reply With Quote
Old 02-28-2011, 09:01 AM   #5
Bob O
Member
I'm using the Bevel Box and turnbuckles. Checking and adjusting pitch has never been so easy.
Bob O is offline        Reply With Quote
Old 02-28-2011, 02:15 PM   #6
05RAVEN
I was using "Bubble" on my cell phone but I just ordered this one... http://www.readyheli.com/107RC-RC-Lo...e_p_37972.html
T-Rex 500ESP- BeastX, Radix blades, Scorpion 1600kv
T-Rex 450 Pro- Scale MD500D, DFC head, AR7200BX, Radix blades,
SPEKTRUM DX8
05RAVEN is offline        Reply With Quote
Old 02-28-2011, 02:40 PM   #7
jerstolp
to answer your ? yes, the align fb rod/tool and a regular old pitch gauge works just fine that is what i used and was super easy. the rc logger digi gauge would be better/easier but is not necessary..
Protos 500 Stretch VBAR 5.1 9650's mks metal gears,ice lite100, bls980, scorp 880kv, 6s
jerstolp is offline        Reply With Quote
Old 03-03-2011, 02:10 PM   #8
chopstick
I do it the way justplanechris says.
For zero pitch, just fold the blades to one side, and adjust the servo's in the setupmenu. turn the head around for the other servo's. On aileron don't forget to adjust the half of the distance between the blades on the left servo, and the other half on the right servo.
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV
Quad 250 : Openpilot CC3D
chopstick is offline        Reply With Quote
Old 03-03-2011, 03:16 PM   #9
seemore74
As mentioned before, this bad boy: http://www.align-trex.co.uk/logger-d...07-p-1815.html is where it's at, way better value for money compared to the beastX digital gauge, much lighter & not so fiddly like the regular digi gauges because of how sensitive they are& the digi gauge unit can be removed from the blade clamp unit.
Shape 9.0, Trex 700 DFC pro** MKS Cyclics & Rudder Servos all round. Kontronik Pyro 750 Drives, Kontronik ESCs
Futaba SBus Rx, Futaba 8FG** transmission
seemore74 is offline        Reply With Quote
Old 03-03-2011, 03:34 PM   #10
sutty
Okay, so there are various methods by which we can measure it during set-up, each have their merits I guess. I used a digital pitch gauge, and then tried the calculated spreadsheet version, works very well. But, this having been said, how do we know what our cyclic pitch range is that is available to us in each of the modes, or doesn't this even matter.
For example, I used to like to know on my previous set-up what my cyclic pitch was, so I could compare to what others said was sensible, too fast, or whatever. During set-up, we only give the MB limits, like the endpoints of a gyro. Sure it can use those limits, if it feels the need, but how can I measure what full stick will give me, without the influence of MB, for any given mode? In set-up you can't, and on the bench you can't, because as we all know the cyclic behaves in a well weird way on the ground, just like an HH gyro.
How do I know what I get allowed to be passed by the MB in Tx mode, with endpoints of 110%, or 80%. Can this be measured? Or do I even need to know? I know that during my set-up, I had no binding, I could max out my cyclic ring set-up step, and if measured here, I think I recall it being 16 degrees, but this doesn't relate to my FB set-up, which was 9 degrees, and this was so fast it was almost unflyable. All the built in modes were too tame for me, and on Tx at 110% with 20% expo it is still slower than my previous set-up. Actually I like it now anyway, it is making me fly better, but my question is how do we know what the cyclic pitch is, not the limits, can it be measured, or does it not even matter, i.e. just go fly, if you like it then it's right.
Cheers
Sutty
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE B, FBL Trex450Pro B,
sutty is offline        Reply With Quote
Old 03-03-2011, 10:34 PM   #11
akamullen
Just set your cyclic limits to right before binding, then go fly. Set your transmitter rates to what feels right to you. I never really measure cyclic, as I adjust to what feels right for me at the field. There really is no need to know what the pitch actually is. I think I checked on my Gaui X5 just to see what the cyclic was for the limits and it was set to around 15. But when flying it is not 15. thats only the endpoints set up for mb.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 380/500-x2/630/770 * Swinging SWITCH/RJX/RAIL & SAB Blades * Microbeast/IKON * Castle ESC's on all * DX18 *
akamullen is offline        Reply With Quote
Old 03-10-2011, 04:01 PM   #12
rocketscience
I was waiting on the tool but I happened to have one of these. Self Leveling laser level and plumb line. Pictures are to illustrate. Line everything up perpendicular and parallel to get best results.
Great for finding that 6 degrees and setting max/min collective and cyclic limits if you get some interactions.
Line up the main shaft first
Then measure
If you don't have one then it's probably not worth it as they're a bit pricey. Or you could convince the wife all the pictures will be straight and all the 50 mirrors she has because of course a straight mirror makes you look thinner..
Paul
rocketscience is offline        Reply With Quote
Old 03-10-2011, 11:24 PM   #13
wrathofkhan
"because of course a straight mirror makes you look thinner.."
LMAO ...
wrathofkhan is offline        Reply With Quote
Old 03-11-2011, 07:48 PM   #14
rocketscience
LMAO ...
whatever works, right? Appeal to their femininity. Or skew it.
Old 03-13-2011, 06:07 AM   #15
Chrisk7
I took a 24" level and drew a series of parallel and vertical lines (grid pattern) on my shop wall across from the work bench.
I just set the heli on the bench and check to make sure the mainshaft or top of the frames matches the marks on the wall then use a regular pitch gauge to check the blade pitch to the lines on the wall.
This also helps when setting up the mixing arms, and flybar paddles on fb heli's.
I just rotate the head and step back a little ways to eyeball the links etc. to the lines on the wall at mid stick in idle up 2 at 0 degree pitch.
"Don't believe everything you think !"
Chrisk7 is online now        Reply With Quote
Old 03-13-2011, 10:44 AM   #16
Bob O
Member
rocketscience,
Excellent idea AND pics.
Old 03-13-2011, 11:50 AM   #17
Helico-pteron
+1
Helico-pteron is offline        Reply With Quote
