Belt CP E-Sky Belt CP
Old 02-27-2011, 11:34 AM   #1
dayshaddow
Default 450 flybar lock
hi all
im looking for a 450 flybar lock for my hk450(mt i think).anyone know of a good place to get one..i dont wanna spend a tonn on something i rarely use...famous last words i know oh and while im here glass fiber blades would be nice..these cf ones are nice but i wanna smash em up and just go oh well..the weather is changing here and i have just been flying my hk for the first time since last october im currently using 315 align cf blades but have to wonder if an extra few ml will make much differnce in lift i still have a tonn of belt cp woodies and i recon the esky cnc grips should just drop on..but i do wonder
cheers
antony
msr msrx tr250 hk450
2 planks
wat for foamy and eflite beast
1/8th Brushless LiPo Powered monster Truck and a maverick strada evo xt
dayshaddow is offline        Reply With Quote
Old 02-27-2011, 11:51 AM   #2
CyprusDave
This guy made one
http://www.helifreak.com/showthread.php?t=10715
but you have to remove the head button to use it (as you have to do with most items like this).
And thre is the one made and sold by Rick Lohr, don't know what postage to UK would be
http://www.helifreak.com/showthread....169282&page=19
Or the somewhat expensive (and complex) Flylock from Sonix
http://www.sportsmoto.co.uk/acatalog...ock_tools.html
Or e-bay, but doesn't seem to ship outside US
http://cgi.ebay.com/Flybar-Lock-Tool...-/140479722296
Not really a lot of help, I'm afraid Personally, if I felt the need, I'd make one
Helis: Belt-CP, Mini Titan, EXI 450, HK250-GT, HK500-GT, HK600-GT, mSR (all modified/customised). Quads: Q4, nQX, HK250, Custom built 560 Deadcat camera platform. Some planks. DX6i & DX9. And a boat & some HK surface controller thingy.
CyprusDave is offline        Reply With Quote
Old 02-27-2011, 12:31 PM   #3
dayshaddow
the guy making one gets my cash just for the fact he made one..will contact him during this week,im way to lazy to make one and lack proper tools
cheers dave
2 planks
Old 02-27-2011, 01:24 PM   #4
ragge1
give rick an MP , quick delivery
http://rdlohr.com/products.pdf
| Atom 6HV : vbar NEO pro rescue | Goblin 700 : vbar 5,3 pro | HD Cell 500 : vx1e |
ragge1 is online now        Reply With Quote
Old 02-27-2011, 03:25 PM   #5
chansen1953
antony,
I made several .. for 450 and 500's flybar and a very easy..
just get a bit of aluminium bar from the hardware store.. I used 10mmx3mm bar ..
cut a piece about 120mm long. drilled three holes with about 3mm bit,
one in centre, and two at about 50mm out from centre. put a 40mm fine threaded bolt with 2 two nuts on it. You just adjust the nuts , one each side of the alum-bar, so that bar is tight and parallel. It helps if you file a curved slot in the ends of the bolts.. so that it can sit snug onto the fly-bar rod.....
it works a treat and cost next to nothing.. you only need a drill to make it !!
heres a photo of mine attached to a copter-x head.. hope the pics clear enough..
I did use some brass "stand-offs" on the ends of the bolts.. just because I had some and I needed to make the bolts a bit longer..
but you get the idea.. nothing fancy.. but it works fine..
Name:	Fly-Bar Lockd 450.JPG
ID:	211107   Click image for larger version
Chris, DX7 Electronics, Retired BELT CPV2
2 x HK600GT hybrids - + Blade Nano cpx ! DJI/FreeFlight Quadcopter several planks for relax time !
I have not failed, I have just found 1000 ways that do not work.
chansen1953 is offline        Reply With Quote
Old 02-27-2011, 06:34 PM   #6
Tomstoy2
I just use my little level on the flybar,,,,, on my one remaining bird, that is.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel,
PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv.
Tomstoy2 is offline        Reply With Quote
Old 02-28-2011, 12:10 AM   #7
CyprusDave
That's it Chris, hardly anything to it Now if you want to get fancier, and have another use for those small diameter taps you just bought, you could drill and tap the outer holes Then only one nut needed
Old 02-28-2011, 12:11 AM   #8
CyprusDave
Yeah Tom, rub it in
Old 02-28-2011, 01:37 PM   #9
dayshaddow
Originally Posted by chansen1953 View Post
antony,
nice one mate.its so simple looking im guessing my diy skills could cope with that
antony
2 planks
Old 02-28-2011, 09:50 PM   #10
chansen1953
yes tom .. very good observation..
", you could drill and tap the outer holes Then only one nut needed "
It would then be even easier to adjust up tight.. just need a screwdriver to wind the bots down.. and snig the nut up hand tight.. might be even better if you could find a wing nut of a small diameter for the underside nut !!
I don't' use these anymore, as I am selling all of my 450's and have sold the 500
The 600's are so big you can easily fit a spirit level bubble on the swash with a bit of plasti-tac and this makes leveling very easy..
Old 03-01-2011, 02:39 AM   #11
CyprusDave
Small nuts (including wing nuts down to M3), bolts, taps and dies available here
http://www.modelfixings.co.uk/index2.htm
